NEED to know what spark plugs to get
Old 04 Aug 2003, 11:40 am
Send a message via AIM to ptcruzin42
Default NEED to know what spark plugs to get
Hey all, I need the help of the gear heads here for a minute. I am having my stage one kit installed next monday and while they are doing the work I am also having some mopar performance ignition cables installed and I wanted to get my sprak plugs change dout too, problem is, I have no clue what kind or size or anything of spark plugs to get. Can someone please tell me the best company, style, size, or any other information I may need to know, to get the best plug for my turbo engine.
Thanks
JB
Old 05 Aug 2003, 10:31 am
Anybody? Like 50 people have checked this post out, yet no one can type up a quick answer, I need to know this, anyone? please?
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 05 Aug 2003, 11:12 am
PTCruzin42, I use the Champion single platinum plugs Gapped@ .042
The champion# is 3032, and the plug code is RE10PMC5. These plugs are 1 heat range colder than the stock plugs. I currently have Magnecore 10MM Racing Plug wires and a Screamin Demon High output coil as well. This setup works great. Be sure to gap lower than the .050 recommended by the mfgr or you may get misfires at High RPM.
I currently run a TurboXs dual stage boost controller,w/boost on the 2nd stage @ 13.5 - 14 lbs boost, so stage one higher boost should be no problem on this ignition setup. I don't care much for champion plugs, but I have found no one else who makes plugs to fit the cruiser. BTW SRT-4 plugs will not work, (different cylinder head construction) not enough reach, and NGK, and denso Iridiums do not have enough Hex Shoulder to tighten into the cylinder head. Hope this helps. [8D]
Alan
Old 06 Aug 2003, 02:48 pm
Hey Gear head, I find that that head on the SRT-4 and the GT have the same part number. Also the hot rod aricle on the GT Turbo engine says this "The cylinder head is the same for turbo and NA engines, though the boosted application uses Silchrome-1 intake valves and Inconel exhaust valves". My understanding is that the only difference is the intake set up and the PCM. I don't see how the SRT-4 spark plugs won't fit. No flames intended, just asking....
Mike
Old 06 Aug 2003, 04:54 pm
The PT cylinder heads have a counterbore that effects NOTHING except the type of spark plug being used. I have pics to post, as soon as cardomains web site is a little less busy, I'll post them.
Here is the SCOOP on the SRT-4 Plugs vs the PT GT Plugs.
Alan
Old 06 Aug 2003, 05:54 pm
Great work Alan!
The only plugs I have found that will fit other than the stock Champions are Champion RE14PLP5 Double Platinum plugs.
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC — The WooX 30w x 2 powered subwoofer
Old 06 Aug 2003, 06:34 pm
I got the RE10's in mine and they work great. They art gapped at .39.
Old 06 Aug 2003, 08:34 pm
I wish that I could take credit for the work, but this came from the PTCC forum. Bob Stockum did all of the work, all I did was figure out how to get it posted here. But it illustrates why its hard to find other plugs that fit. These plugs are the same plugs that go into the V6 minivans (so I have been told). DC must have had to do the counterbore strictly in order to use these plugs. Like I said, i don't care for champions but these seem to be working great AND THATS ALL THAT COUNTS !!
Alan
Old 07 Aug 2003, 12:49 am
They are also in the 2.7L Stratus. It takes the 10's.
Old 07 Aug 2003, 09:24 am
So if the counter bore is the ONLY difference - is DC protecting a cross market deal with Champion. I've contacted NGK and they are "in development".
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
E3 Spark Plugs CREWZIN Tech & Performance Forum 6 11 Dec 2004 01:03 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
