Turbo maintainence
Old 07 Oct 2008, 07:03 am
Default Turbo maintainence
I was wondering what other major maintainence comes after 100,000 miles, which I'm fast approaching... I just did the timing belt and water pump. how many miles can we get out of this engine? others with high milage chime in please.G
Old 11 Oct 2008, 12:37 pm
Default Re: Turbo maintainence
Sorry Gary, looks like nobody wants to chime in.
When you did the timing belt and water pump did you have the mechanic check the serpentine belt, tensioner and alternator belt? Those are all things that should be looked at and probably changed along with the timing belt because the the wear and tear of that many miles.
There's no reason why the PT, turbo or not, shouldn't go another 100,000 miles if maintenance, including flushes for the transaxle (if it's automatic) is kept up.
The front end suspension including bushings, hubs and bearing on both sides should also be checked out periodically.
Old 11 Oct 2008, 01:09 pm
At 100k we had the timing belt, water pump, serpentine belt replaced. Also had the injector service and the cooling system flushed and refilled. We have an auto and have the tranny serviced every 30k alternating between the drain and fill and the full flush service.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Blow Off Valve Conversion Kit gonzomania Tech & Performance Forum 10 08 Sep 2004 09:08 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
