Diablosport Predator for Cruisers
Old 08 Oct 2008, 10:10 am
nevinsrt's Avatar
Default Diablosport Predator for Cruisers
U7134 now available for purchase!!
U7134 Has been tested and released Version 9r02 Includes: 03-05 SRT4 03-05 PT Cruiser (CMR tuning only) No TCM support for automatics at this time. It will added at a later date. Mopar Stage 1, 2, 3 PCMs with and without Turbo toys Adjustable Parameters: Boost Control, WOT Fueling, MBT Timing, WOT Timing, Fans, Idle Speed, Rev and Speed limiters.
U7134 Neon SRT4 tool released! - .:SRTConnection:.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 11 Oct 2008, 10:56 am
Default Re: Diablosport Predator for Cruisers
Anything for an 07 Limited Turbo Auto?
