Clutch
Old 09 Oct 2008, 07:40 am
Default Clutch
How do you know if your clutch needs to be replaced? does it show wear like with brakes, getting soft? I never read any posts about your clutch?????
Old 09 Oct 2008, 10:39 am
crusierdad76's Avatar
Default Re: Clutch
well id say if it starts slipping when you take off, or maybe not slipping as much as a chatter like feeling , or if you are really getting on it it can slip and you will smell burnt clutch.
yes, clutches do ware just like brakes, and they also have top be replaced, but usually folks will get way over 100,000 before that happens. On today's clutches there are hydrolic slave cylinders that will also go bad, this is usually a bad thing and will usually act like the clutch is gone out, and as bad as it is usually when you have the slave cylinder replaced you might as well go and have the clutch replaced as well since they are already in the same area.
Old 09 Oct 2008, 01:15 pm
Default Re: Clutch
Try cruising along at 30 mph in 3rd gear and then punch it. If your clutch is slipping you'll hear the motor rev without going anywhere for a second or two. That's slippage.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 09 Oct 2008, 02:59 pm
Default Re: Clutch
and if it really slipping it leaves such a sweet smell everyplace
Old 09 Oct 2008, 03:46 pm
soonercruiser's Avatar
Red face Re: Clutch
On my "Limited", I began by having trouble shifting between 1st and 2nd. It was probably the slave cylinder that disengages the clutch plate.
**But, that replacement is now one complete assembly. Mine was at 24K!
Frank, aka SOONERCRUISER,
New Clutch went bad after 2 weeks??? Ctown Tech & Performance Forum 7 25 Sep 2009 03:40 pm
TECH QUESTION - CLUTCH ASSEMBLY soonercruiser Tech & Performance Forum 3 08 Jul 2008 08:24 pm
clutch and slave cylinder chops660 Tech & Performance Forum 2 21 Nov 2007 01:32 pm
Review- New performance clutch install for the GT FastNJPT Turbo Performance 2 26 Sep 2006 10:13 am
Clutch Problems? ptgtcb General Turbo Discussions 2 24 Apr 2004 12:11 am
