Custom Intake
Old 31 Oct 2008, 02:25 pm
Send a message via AIM to Hitman9853
Default Custom Intake
Has anyone made there own intake. And if so what parts are needed to complete the install. Also pic's will help as well.
Old 31 Oct 2008, 02:39 pm
Default Re: Custom Intake
There might be 1 or 2 that sort of made their own but what are your intentions? Do you want one that looks good, sounds good or works the best? For one that works the best meaning it lets only cool air in at a slightly higher flow than stock then a modified stock system is best for the turbo.
Old 31 Oct 2008, 02:40 pm
To change the turbo to air box pipe
Old 31 Oct 2008, 02:47 pm
If you mean the chrome pipe from the throttle body to and open air filter, that will give you a lot of sound but also draw in warm air from the engine. It looks good (depending on what system you buy) and if your not into squeezing every bit of HP out of your Turbo, there's loads of air box pipes out there for sale.
Here's a link that discusses some of the options:
DIY Air Box mods
Old 31 Oct 2008, 03:14 pm
CREWZIN is correct, you really don't want to go to an open intake with a turbo unless you don't care about losing some torque. If you care then I'd go with the modified airbox, a K&N drop in filter and replacing the turbo to airbox pipe. You can either make your own pipe or purchase it.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 31 Oct 2008, 03:19 pm
do you have any idea of the size of the pipe from the turbo and angels needed.
Old 31 Oct 2008, 03:42 pm
Go here. Reinforced Silicone Couplers: Silicone Hump Hose, Silicone Reducers (Silicone Transition Hose or Step Hose), Silicone Elbows, Silicone Straight Hose : BoostController.com LLC - America's Source for High quality turbo boost controllers, silicone hose,
You'll need one of these 3" reduced to 2 1/2" #ASRE90-X. Silicone Reducing Elbow - 90 degrees and one of these 3" X 3" couplers #ASCSH3-X. Silicone Straight Hose - 3 inch length
For the 3" pipe you could use some 3" exhaust pipe and paint it the color of your choice.
You will need to add a nipple to the pipe for a vacuum hose. For the nipple you could use a rubber valve core to attach the vacuum hose to. Cut a hole in the pipe and slip the valve core through the hole.
New Custom PT Parts? Candyman Exterior Accessories Forum 33 03 Oct 2008 02:07 am
Custom Made Intake CHROMEDCRUISER Tech & Performance Forum 9 04 Oct 2004 08:11 pm
Custom Cruiser Calendar Contest skylight PT Cruiser News and Rumors 12 17 Nov 2003 12:12 am
AIR INTAKE FROM AMX1397 amx1397 Turbo Performance 6 03 Jun 2003 10:22 pm
Custom Air Intake GTPT Turbo Performance 52 28 May 2003 04:05 am
