intake manifold???
Old 22 Dec 2008, 09:41 pm
Default intake manifold???
i have a question about the gt vs. regular pt. i have been able to score the factory turbo system (oil lines, header, turbo, intercooler, and all tubing). my only this is the intake manifold that wrapps over the top of the engine and goes under neath. is it possible to use the a regular pt's intake manifold? i know that the gt's throttle does curve so that the intercooler hooks up to it.
if not where can i purchase the intake manifold(the one connected to the throttle and the other half that goes underneath into the engine?
Old 24 Dec 2008, 12:56 am
Default Re: intake manifold???
Are you attempting to install the turbo on a factory N/A engine? There are probably a few more things you will need such as the pcm. Also the factory turbo engine is not exactly the same as the N/A engine, example the extra oilers on the turbo. I would do a lot of research before attempting this.
The intake manifold you are referring to is the intercooler piping. N/A PT pipe will not work.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 24 Dec 2008, 08:06 am
Agree w/KLCruiser.
The turbo engine has stronger connecting rods than the N/A - plus other changes - you can't just slap on the external turbo parts - and there is also the engine computer (PCM) and controls...
Old 24 Dec 2008, 12:36 pm
i understand the oilers and obviously a new computer...so would i be better off just buying gt motor off ebay. because it sounds like i'd spend just as much trying to fabricate itmy motor.
Old 24 Dec 2008, 01:25 pm
Originally Posted by PTcruzer02 View Post
i understand the oilers and obviously a new computer...so would i be better off just buying gt motor off ebay. because it sounds like i'd spend just as much trying to fabricate it my motor.
I'd buy a gt motor. The na motor is weak.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 26 Dec 2008, 10:58 pm
And you'll still need the GT PCM. Stage 1 PCM would be even better.
intake manifold painting??? careyk General PT Cruiser Discussions 1 25 Jul 2008 02:42 pm
Plastic Intake Manifold cracked-boost leak! littleblueGT General Turbo Discussions 1 31 May 2007 03:25 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
DRILLED INTAKE MANIFOLD FOR BOOST GUAGE amx1397 Turbo Performance 6 24 Feb 2004 02:50 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
