without one...
  #11 (permalink)
Old 28 Jan 2009, 09:43 am
nevinsrt's Avatar
Default Re: without one...
Originally Posted by superpug666 View Post
THANK YOU SOOOOOO MUCH the srt4 sounds awesome, the pt also. The pt seems to have the exact same music, but on a higher lever... On your opinion how would it sound if the last foot or so would be 3inch to 3.5 inch?
thanks so much again...
PS my wife is pissed at you because she just saw the vid (27th january) and the forecast for tomorow is between 15-25 cm or about 6 to 10inches of snow...she saw how nice the weather was in your vid. lol
no sure it probally just sound the same.
since your playing with the exhaust just get an E-cutout or a full 3in.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
