Headers?
Old 20 Aug 2003, 10:55 am
Default Headers?
What benefit are headers on a Turbo and what type is best? 4-2-1, 4-1, ceramic, cast?[:I]
Old 20 Aug 2003, 11:05 am
There are no headers to fit the turbo. The turbocharger is built-in to the exhaust manifold.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 20 Aug 2003, 07:37 pm
Just to add on...even if it wasn't built into the exhaust manifold, turbo cars use a down pipe. As a general rule of thumb, any sort of "breathing" tube on turbo cars you want to be as BIG as possible.
My Cruiser is slow. I love the law.
Old 20 Aug 2003, 09:02 pm
Headers will help out quite a bit but the design questions aren't as simple as 4-2-1, or 4-1 or cast vs. welded tubes (with or without ceramic coatings).
Headers help the flow out of the exhaust gases get out of the engine. The expanding gases turn the turbine side of the turbo then leave down the down pipe out the exhaust system.
A turbine operates on a pressure differential/change and your header design must take that into account. If the volume of your header is too big (i.e. tube diameter is too big or pipe length is too long), you will have a low pressure in the header and the turbine will not spin quickly (turbo lag). As the gas flows, it likes to go from high pressures to low pressure and the header is quite the balancing act. It goes from Cylinders->Header/Turbo->Downpipe/Exhaust. So you are balancing Cylinder pressure vs. Header Pressure and Header Pressure vs. Downpipe.
I know that this wasn't the simple answer you were looking for Airbillster, and I do tend to go overbored on technical questions but your question was quite open-ended. That being said, it is hard to get someone to cast a header for you (very expensive) and it is easier and cheaper to have one made from mandrel bent piping. I know this because I am in the process of making a turbo header (not for the PT's) and it isn't easy. The gains that I have seen thus far from other turbo header applications is approx. 30HP on a turbo car that made around 200HP with a standard manifold. Keep in mind that greater gains will be had going from a poorly design manifold to a nice turbo header.
Marc
2003 PT Cruiser GT Turbo, Silver
1985 Dodge Omni GLH Turbo 16V, Black
http://connect.to/YBT
Headers.. Are they worth it? harbinger225 Tech & Performance Forum 3 24 Oct 2005 05:14 am
Headers TaylorMade Tech & Performance Forum 28 06 Oct 2004 09:38 pm
Headers for 2003 Turbo David Graham Tech & Performance Forum 2 27 Oct 2003 05:26 am
Headers namvetmike Tech & Performance Forum 3 18 Mar 2003 05:42 pm
APC headers ludwig General PT Cruiser Discussions 0 21 Mar 2002 04:26 pm
