THE WHOLE TRUTH PART 2
Old 22 Aug 2003, 02:23 pm
Default THE WHOLE TRUTH PART 2
Sorry so long geting back,but my computor stoped working,and i am at the a public one.But back to the truth.I went to the 1/4 mile track,got there early,in 1 hour made 8 runs,6 changes,without shut the engine off and corrected for weather changes 3 times.With a full tank (About 3550 lbs.) 2 Blast out runs on street then 1 hr. cooldown
1st run 15.67/88.03 2nd 15.72/87.40(warmed up)now add .025 bleed hole in waste gate hose
15.48/87.65 add now .030 hole 15.42/87.65 now remove both air box silencers 15.37/89.42 now remove air filter(used 5000 miles) 15.33/89.49 now .036 hole 15/24/90.37 now not contiue to idle off line,trying 2000 gas & brake 15.11/90.70 (Came out burning like a fuel burning dragster) Well no 14s,but I had fun.Going to install my stage 1 and then back to the 1/4 mile,I feel this is the only 100% good testing that i have seen on this sight.I am sorry i won't be able to answer any of your posts because my computor died or till its fixed OLDHEAD
Old 24 Aug 2003, 05:27 pm
Good going this gives me a good idea how effective each of your mods has been for you! Thanks
Old 27 Aug 2003, 11:38 am
Send a message via AIM to Steve03GT
thanks for the info. It appears you improved .11 secs after removing silencers and filter which equates to a rule of thumb ~10 hp at the strip. this is great empirical data, I've been concerned the air intake flow may have been outside the PCM look-up tables, apparently not. Great news for all of us who've modified our air intakes.
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges
\'02 Corvette (510 RWHP/510 TQ)
Member of 11sec. club &
NRA Benefactor Member
Old 27 Aug 2003, 07:27 pm
Wasn't Old head the one that said that removing the silencers won't do anything???
Old 27 Aug 2003, 08:05 pm
Removing the silencers did good for me at minimal/no cost but the new K&N Typhoon air intake system makes my car sound like about another 15 hp!!! Waiting on realeas of the system before K&N will release dyno numbers! It does quiet down on Highway so I only can hear it when I accelerate. Now I know when the turbo is working though since I never spend the money for a turbo guage. BTW it works almost all the time when I accelerate even a little bit!!
Old 28 Aug 2003, 01:08 pm
OK OK:so i was wrong,but i told the truth,by the way 15.37 from 15.42 is .05,I feel all the changes i made was worth 27 hp.I also think that if i would have cooled down for 2 hours that i would have turned in the 14.9s.By the way i did see boost as high as 16#(surge),when it cools down in about a month,i will put on my stage 1 and run again.And my computor is broke for good i think,so i won't be posting as much.OLDHEAD
Old 28 Aug 2003, 01:48 pm
Couple of thoughts about your times. Weight is a killer in drag times as is traction. Did you take out all your back seats? Not sure why you filled up with gas exept that you wanted to make a lot of runs. Most hot times are recorded with not more than 1/4 tank of gas. Cooling off intake with dry ice is a good way to insure optimal temp in intake system. I tink you have a 14 sec car just have not achieved the results yet. You might even get into te 14 sec bracket by not using the traction control, maybe you didnt, or by choosing another take off technique! Exept for the mods stated is yours a stock auto?? If so what rpm did you shift or just floored it and let auto upshift in stick mode?? Love to see a stock auto break into 14's with low cost / minimal cost mods only. BTW if you are going for stage 2 yo will need exhaust mods!
Just my thoughts I am impressed that you actually got off your ass and did some fun stuff!
Old 02 Sep 2003, 04:21 pm
very cool times !!
Old 02 Sep 2003, 04:38 pm
Do you have any idea when K&N will be selling the Typhoon for the 2003 GT?
2003 Electric Blue GT. Mods - BTG lowering springs, Polished Blane hood struts and hatch strut covers, chrome door handle scratch guards, molded rear splash guards, BTG polished strut tower brace, BTG axle back exhaust, K&N drop in air filter with baffles removed, Royal Purple synthetic motor oil and K&N filter, Polished front and rear sill plates, Chrome \"PT CRUISER\" rear license plate frame, chrome door spear covers, Chrome antenna bezel, Get the BEST detail products from Gary here: http://www.perfectautofinish.com/
See my PT and mods here:
http://www.imagestation.com/album/?id=4289059783
MY EMAIL ADDRESS: stephenlarson@adelphia.net
Old 02 Sep 2003, 05:13 pm
GTSTEVE, no idea just that it should be soon. I have a call into them today and when they return it I will post their answer or lack thereof!! All I know is that they said I could upgrade to a different finish (mine is kinda prototype natural aluminum) when they go public and they will give me the dyno sheets for my car with the Typhoon installed to go along with baseline number they gave me about 3 months ago!
Confused about Magnecor 8.5mm part no im4gzs Turbo Performance 13 11 Oct 2009 02:16 am
Mistery part... Annyone? Ian-PT-GT General PT Cruiser Discussions 2 04 Jan 2006 01:11 am
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
Do you need this part? KingKole02 General PT Cruiser Discussions 3 09 Jul 2004 04:06 pm
Mopar Warranty & Stage Kit Part Numbers skylight Stage Turbo Kits 35 08 Feb 2004 12:23 pm
