Pics of Custom IC Sprayer on the GT
  #11 (permalink)
Old 24 Aug 2003, 11:04 am
It is all in the usage...
Don't turn it on untill you have started to move. The incoming air will push it inside the cooler and I am sure It will evaporate before it reaches the track.
Just Two cwnts.
Ian
  #12 (permalink)
Old 24 Aug 2003, 12:25 pm
quote:Originally posted by wagonmaster
Chipmunk,
Your local track will likely have a fit if they see you spraying water on their track! The fast cars with slicks REALLY don't like water under their tires except in the burnout area behind the starting line. A 12 second car that hits water in 2nd or 3rd gear could likely hit the guard rail! Please be sensible with your creation. I think it's a great move, by the way! Just not for the drag strip.
Joe (old drag racer)
Yeah I know, Im Changing the sprayers to the Misting kind. This will solve that problem.
\'03 Yellow SRT-4
  #13 (permalink)
Old 25 Aug 2003, 01:24 am
Well here are the updated pics with the Misting Nozzles I picked up today at Home Depot. It really works well now.
-=Matt=-
\'03 Yellow SRT-4
  #14 (permalink)
Old 25 Aug 2003, 10:08 am
Nice job Matt, gotta figure out where to mount res on mine ....the shift linkage is where you mounted yours on the 5-speed . I think I could mount the nozzles on my lower grill behind the plate on my crusher but finding a spot for res maybe issue . How are you activating ? Small switch inside car?
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
  #15 (permalink)
Old 25 Aug 2003, 04:18 pm
It would work nicely, if you could install a Micro Switch to the Throttle Butterfly, it would turn on automatictly when you are at wide Open throttle.
This would make it a turn on, and forget item. Water would only come out only when you fully accelerate.
Ian
  #16 (permalink)
Old 25 Aug 2003, 08:21 pm
Nice clean install! Great mod! great job![:X]
  #17 (permalink)
Old 26 Aug 2003, 02:35 am
Yeah I got a switch inside. Nothing Special. Or you can buy a "Intelligent Intercooler Water Spray Controller Module" from http://www.autospeed.com
As far as mounting the Resevoir I would also suggest where the Tire jack is in back. I think I may move mine back there as well, no heat back there to warm the water and you can fit a bigger tank there as well. Currently my transformer for my Underbody neons sits back there with the wires coming up through 2 holes at the bottom.
\'03 Yellow SRT-4
  #18 (permalink)
Old 01 Sep 2003, 10:24 pm
Send a message via AIM to Exhaust Depot
Try using alcohol instead. It vaporises quicker which means it cools faster. Nice setup!
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
  #19 (permalink)
Old 03 Sep 2003, 08:59 pm
That was my thought exactly, I used to put alky and ice in my fuel cooler on my old race jeep.
Tom
My custom pics (finally) turbomangt The Detail Shop 7 13 Mar 2005 10:21 pm
Finally, my custom pics PTurbed General Turbo Discussions 14 12 Mar 2005 02:24 pm
Custom dash Pics turbomangt Exterior & Interior Styling 6 22 Jul 2004 10:04 am
Pics, custom dash CREWZIN General PT Cruiser Discussions 7 16 Jul 2004 09:39 pm
Custom Turbo PIcs flashbk2 General Turbo Discussions 7 27 May 2004 11:37 pm
