21 Apr 2009, 10:06 am
Re: exhaust & BOV
Originally Posted by JaviPTGT
i have had a mopar bov and now have a Graddy type s. I just want some thing new. Any ideals i was thinking about getting the HKS ss but i dont like the sound. My exhaust i have had 3 kinds. Currently i have a 2 1/2 straight pipe to the side exit. I was thinking about getting duels but dont know,
I have a 03 GT any input is helpful thanks
the HKS has different inserts you can choose from, if you dont care for one sound you can make it sound differently do a google search and see what sound you like. all you do is buy the HKS and buy the insert seperate and install.
theres no insert, purple insert, gold insert
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
