Oil Dipstick Difference When Changing from Aluminum to Composite Manifold
Old 22 Apr 2009, 04:17 pm
Default Oil Dipstick Difference When Changing from Aluminum to Composite Manifold
Hi. I have the composite manifold and want to install it on my 2003 PT Cruiser turbo and I've read about the dipstick differences. What exactly is the difference or what does the newer dipstick that will fit with the composite manifold look like? Is the newer one longer? Or what? Thanks for any input.
Old 22 Apr 2009, 08:13 pm
Default Re: Oil Dipstick Difference When Changing from Aluminum to Composite Manifold
From my understanding, it isn't the dipstick, but the support for the dipstick tube. Mine came with the plastic manifold.
Take a good look at the tube and you ought to be able to figure it out. If not, post on PTCREW - lots of members there swapped from aluminum to plastic on their turbos.
Old 22 Apr 2009, 08:56 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
The little bracket on the tube itself does not line up with the threaded hole for the screw on the plastic manifold if you are trying to use the one from your metal manifold. Easy fix, just get a little "L" bracket or a couple different sizes and a little nut/bolt and make it work.
Or you walk on to any dealership and swipe the VIN off a new turbo and order a dipstick tube for that car.
Its not a big deal either way you are out $5 dollars in parts either way.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Old 22 Apr 2009, 09:12 pm
Thanks, I'll look into going to my local Chrysler dealer and see about ordering an updated dipstick tube. I wanted to make sure I had everything before I tore it apart. Thanks again for the help.
Old 23 Apr 2009, 05:37 pm
dipstick tube is P/N 4777964AB per my reciept when I bought my manifold
Old 23 Apr 2009, 06:18 pm
Thanks mine was done so long ago the paperwork lost in a box still packed from the move a year a 1/2 ago..
