Turbo not working
  #11 (permalink)
Old 28 Apr 2009, 01:31 pm
Default Re: Turbo not working
Thanks guys. Have to go to work now, guess it will have to wait till tomorrow.
'05 Black GT Convertable.
  #12 (permalink)
Old 30 Apr 2009, 11:13 am
nevinsrt's Avatar
do a boost leak test.
go to home depo or lowes and get a 2in rubber plumming cap. then go to autozone and pick up a valve stem. make a small hole in the cap and push the valve stem though and then take off you intake pipe and put it on the turbo and fill the system with air. where ever you hear air leaking from, use a squart bottle with soap and water to pin point the leak then fix it with either zip tie or tighten a clamp.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
  #13 (permalink)
Old 11 Jul 2009, 07:07 pm
I have an 06 PT GT with 55k. I took it for various small problems including the turbo sometimes not seeming to work. The dealer called me and said they have to replace the turbo because the pressure relief (pop off valve) is bad. They told me the turbo spools up but no real boost. Im glad I bought the extended warranty!
BTW.....if u have a turbo......use synthetic motor oil and change the oil every 3000 miles.
  #14 (permalink)
Old 11 Jul 2009, 07:35 pm
Actually, using synthetic oil you can go 6k miles between changes. 3k miles is a waste, though some still do it. Dealer recommended 6k miles and I've been doing that with my turbo cars with no problem and my cars aren't exactly stock.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #15 (permalink)
Old 11 Jul 2009, 07:59 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Your not stock but I would shorten that interval if you are track pounding the car back to a 3k interval or anytime you suspect an issue.. Or at least change the filter at the 3K intervals and just top it off like BMW does..
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
  #16 (permalink)
Old 16 Jul 2009, 07:46 pm
ChefTank's Avatar
Ps- old thread but wga arms (stock & aftermarket) can break and cause these symptoms.
Josh
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Stage 1 Kit official or aftermarket? vash382 Stage Turbo Kits 30 03 Jul 2009 03:58 pm
Is my Turbo really working?? Lavaman General Turbo Discussions 3 20 Aug 2007 12:18 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
