Turbo not working
Old 28 Apr 2009, 07:32 am
Unhappy Turbo not working
Am new here, so I hope I describe all this satisfactorily.
I have a 05 GT with about 65,000 miles. I cheked for error codes and it just says "done".
my turbo does not seem to be kicking in at all. When I step on it, the engine revs high, but there is no real power. At lower RPM the power seems about normal. But higher it seems like the engine is straining. I have no mods other than a KNN filter.
Any advice?
Old 28 Apr 2009, 07:44 am
Default Re: Turbo not working
Welcome.
Noise different than usual?
Check all the air hoses - to/from the intercooler - bet one slipped off...
Old 28 Apr 2009, 07:55 am
No, no different noises. I will check the hoses
Old 28 Apr 2009, 08:04 am
Checked the hoses and all seem OK. All are attached and I can't see any cracks
'05 Black GT Convertable.
Old 28 Apr 2009, 08:37 am
take the top of your air box off while its running and rev engine listen for turbo, mine will not spool up untill its hitting high rpms.
Old 28 Apr 2009, 08:39 am
allso, i found broke vac line on mine the other day.
Old 28 Apr 2009, 11:47 am
OK I am an idiot. Now that I am actually listening for the "whine" that the turbo used to produce, it is not there. So I am guessing the turbo went out completely? Without sounding completely stupid, is there a way to "reset" the turbo, or a fuse that could go out.
Thanks again for the help. I am not really mechanically inclined.
Old 28 Apr 2009, 01:01 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Turbo spools boost at about 2500 rpm.. An auto though in park will not allow reves above 3000..
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Old 28 Apr 2009, 01:08 pm
Not a stupid question, at all.. Nope its all mechanical.
Turbo is powered by exhaust gas, which turns the tubine which takes force fed fresh air compresses it, spits through the intercooler(rad for air) cools it down then shoves it into the motor = power and lots of it.
I would wonder if you don't have a monster boost leak.... They don't need to be cracked hose to produce really limp boost numbers.. The rubber pipes over time get brittle and worm gear clamps eat into the rubber and the vibration over time can wiggle them off just enough that boost slips through like hurricane katrina - producing a really wimpy turbo..
double check the turbo connection from the airbox to the turbo itself and the lower intercooler pipe just front of the drivers side tire. These are two hardest to see and get to places - neglected and overlooked and harder to get nice n' tight.
Too bad you don't have a boost gauge(hate that chrysler didn't install one) so we could see if you are boosting what you should or if its falling flat on its face or just never boosting enough or at all..
Old 28 Apr 2009, 01:09 pm
You can't look at the hoses and tell if they are leaking or not. You need to zip tie all vacuum hoses and use t bolt clamps on the intercooler hoses. Turbo cars are famous for boost leaks, even straight from the factory.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Stage 1 Kit official or aftermarket? vash382 Stage Turbo Kits 30 03 Jul 2009 03:58 pm
Is my Turbo really working?? Lavaman General Turbo Discussions 3 20 Aug 2007 12:18 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
