coolant question
Old 08 Jun 2009, 08:35 pm
Send a message via Yahoo to sandylolee Send a message via Skype™ to sandylolee
Default coolant question
Can you use another brand of coolant in an 05 turbo rather than the 32.00 a gal mopar coolant?
2005 gt inferno red airbox silencers off K & N sounds good
Old 08 Jun 2009, 09:21 pm
Default Re: coolant question
It has to be a HOAT antifreeze, Hybrid Organic Acid Technology. If you use the wrong antifreeze you can get bad corrosion in your system and/or your waterpump could fail. Keep in mind it's a 5 year/150k mile antifreeze. It's not like you are changing it every year. It's not that expensive when you average it out over it's life expectancy.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 Jun 2009, 08:25 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
zerex G5. it runs around 13.00 a gallon at your local carquest or napa.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Coolant Problem DIYPTGUY Tech & Performance Forum 12 04 May 2009 03:25 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
Turbo coolant hose blew-heads up! littleblueGT General Turbo Discussions 2 18 Oct 2007 08:22 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
Coolant drain Chz Stage Turbo Kits 6 19 Aug 2003 02:58 pm
