WHAT'S BEST TO SHIFT AT REDLINE OR TO SHORT SHIFT @5,200 RPM, HP PEAK'S THERE WITH THE STAGE I. I FEEL LIKE AFTER THAT IT'S JUST A LOT OF NOISE AND NO REAL PULLING POWER. ANY INPUT?[8)]
General rule of thumb is 10% past the HP peak. So when you shift, you will fall back into your HP range to maximize the area under the curve. So if your peak is at 5200RPM, then you should be shifting a tick over 5700RPM.
Are you going by the dyno chart that Mopar gave you for peak HP? Dyno testing is the best way to determine peak HP and thus optimum shifting points.
Marc 2003 PT Cruiser GT Turbo, Silver 1985 Dodge Omni GLH Turbo 16V, Black http://connect.to/YBT |
YES, I'M USING THE CHART FROM MOPAR, THANKS FOR THE INPUT, SOUNDS ABOUT RIGHT TO ME.
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715 |
GLH is right on, think about it, if you shift right at peak hp, you drop below it, shift past peak and you fall much closer to peak hp.
Tom |
I don't know if this makes much sense, but here is an interpretation of the torq/hp curves that was posted in the SRT-4 forum to a similar question:
That was a discussion about the Stock 2.4L Turbo Torque/HP curves. On the Stage I 2.4L on the PT, Torque peaks at 260 ft/lbs from 3600 - 4400 RPM. HP peaks at the 5200 RPM mark. I also agree that the 10% past the HP peak is a good rule of thumb. Dyno testing will be the way to go in determining whether to use the HP peak + 10%, the torque peak or somewhere between the two. With the PCM programed for Torque based boost management, and the brick wall inherit 5500 RPM in the 2.4L engine; it is a safe bet that there isn't much reason to go to redline. If graphs and charts can be trusted, a shift much past 5500 RPM would be a toss up between loosing momentum due to the engine past it's peaks or the effects of the rev limiter sneaking in. Either way, it amounts to loss of momentum. |
If you have reduced backpressure, you can make good power up to fuel shut-off. I touch it top of third in the quarter, bout twenty yards from the lights.
PT GT - Fastest damn lease car I could hope to have... |
VERY USEFUL INFO, I'M STILL TORNED BETWEEN 4800 AND 5700 RPM.
This is a GOOD thread... i've been wondering this same thing. I'll usually hold till very close to redline before shifting. I've found that shifting around 5000 tends to have a bit of a bog going in to second gear. But when shifting just before redline you land smack in the middle of the power range. Also, if you are power shifting you'll know there is a big problem with wheel spin in second gear. I've gotten much better results by quick shifting into second and slipping the clutch; while still powershifting into third.
My Cruiser is slow. I love the law. |
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges \'02 Corvette (510 RWHP/510 TQ) Member of 11sec. club & NRA Benefactor Member |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Shift Console Wiring Help Please | PtDaddy | General PT Cruiser Discussions | 2 | 30 May 2005 04:30 pm |
| Auto Tranny will shift even if in 1st gear? | BumperBob | Tech & Performance Forum | 4 | 07 Apr 2005 11:07 am |
