gas mileage with Boost controller??
Old 08 Sep 2003, 07:45 pm
Default gas mileage with Boost controller??
I've noticed that when at high boost, i go throuhg gas like a demon. And it's NOT that i'm punching it way more. When i'm not at high boost i can rev. lower at higher speeds, but at the same rpm as with boost i use less gas. Anyone else experiencing this?
Old 09 Sep 2003, 01:42 am
The more boost you run, the more air is forced into the engine, and the more fuel is needed to maintain an ideal af ratio. BTW this is not 14.7:1 in turbocharged cars. Well it might be in an ultra super highly tuned car, but about 10-12:1 is safer especially when upping the boost. Also leaves room to lean it out to increase power when you are tuning it. Your mileage may vary
Mike
90 Eagle Talon Tsi AWD - 300 Hp -K&N, 16g turbo, JE pistons, 3in Turbo back exhaust, mild port&polish
03 PT Cruiser GT - 215 Hp-Airbox and Intake pipe silencers removed
Old 09 Sep 2003, 09:01 pm
I figured as much DSM, but it's nice to get another informed opnion. I'm confused though as to how people with Stage 1 are getting BETTER gas mileage with higher flow injectors, higher boost, and more fuel demand??
My Cruiser is slow. I love the law.
Old 09 Sep 2003, 09:18 pm
I find with the stage 1 I am getting better fuel milage when running under factory conditions. But with my boost controller hooked up forget it at high boost I am lucky to get 250klm per tank, more air requires more fuel minor sacrifice for more performance.
13.88@103mph
Old 10 Sep 2003, 08:35 am
Cop Tzer,
stage one doesn't increase boost all the time, it adds boost on demand. if you accelerate the car with only 25% throttle, boost will be minimal ( 0 - 5 PSI), at WOT it goes to 16 PSI but it drops down once going to a higher RPM range.
With the Manual BOV, it jumps to the set PSI and the drop is minimal. Also, boost will be reached at even 25% trottle. The computer will notice this and increase fuel to protect itself from falure due to lean conditions. The end efect will be incresed HP with low MPG but the engine could feel like the power is non-proportional or peaky. This was the reason I changed to the A'PEXi and later to stage 1. Now I keep my trusty Hallman on the glove compartment and install it at the track. once done, I take it off and get back my drivability.
Just Two Cents.
Ian
Old 11 Sep 2003, 01:28 am
Thanx Ian, that was EXACTLY what i wanted to know about the Stage 1. MUCH APPRECIATED!!
Old 01 Aug 2005, 09:29 am
Hi there,i just got my very beautifull BLUE 2005 pt cruiser,i had a 2004 that was a lemon.and i wone the case and i was intitled to a brand new car of my choice and i chose another pt cruiser,i love it!!.i am almost done with my very first tank of gas and i am only getting 14 miles per gallon,i am a little shocked,trucks get more then that,but it is a cute little car and worth it,though i would like to do what i can to fix this,but i am concerned if i change filters and oil or any thing else that my worrenty would become void,i get free oil changes for the rest of the life of the car as long as i am the owner, this is a concern of mine.
I was glad to read what you all said about the gas milage,i was a bit nervus that i may have had a problem with this car to,but it is clearly not the case.
thanks for the info,i hope i can start to contribute usefull info as you have
barb
i cannot figuar how to post a picture of my baby blue,i bet it is a macintosh issue,are there any mac people out there that can answer that issue for me
thanks
Old 01 Aug 2005, 10:25 am
barb
thanks
I also got free oil changes for life, but changing the oil yourself will not void your warranty! Yes, you will get less mileage during break-in, and the mileage finally starts to settle down once the engine is totally broken-in at between 12-14K miles.
Old 02 Aug 2005, 06:38 pm
You have to post the picture on a web site, and link to that in your post. It's HTML, and the same on either Mac or PC.
Black 03 PT Turbo & Black 94 Impala SS
Old 02 Aug 2005, 10:26 pm
WOW, talk about reviving an old post [8]
That was almost 2 years ago
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
Part Throttle boost with boost controller forcedinduction Turbo Performance 2 18 Feb 2006 01:48 pm
WHAT BOOST CONTROLLER TO BUY? ptTurbo528 Turbo Performance 2 04 Oct 2005 03:08 am
boost controller for less than $10. how to make it bluebluegt Turbo Performance 6 20 Nov 2004 01:36 am
Turbo XS Boost Controller With Adaptor blueberrygt Classifieds: For Sale/Trade 2 08 May 2004 06:08 pm
