pt-tuning strut bar mod ?
Old 09 Sep 2003, 12:06 am
Default pt-tuning strut bar mod ?
was thinking about modding the strut bar (if i receive it), would changing the bolts to some type of quick disconnect type, so the bar could easily be removed for engine work, I'm not sure what the part is called but its a rod with a hole in one end, which a pin slides into.
or does the bar need to be rigid ( the bolts must be tight)
Punch
Old 09 Sep 2003, 12:09 am
http://www.pivotpins.com/clevis-pin.htm
this pin to replace the strut bar bolts?
Old 09 Sep 2003, 12:48 am
Send a message via AIM to Steve03GT
Or, maybe this:
http://www.pivotpins.com/catalog/RngPin.shtml
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges
\'02 Corvette (510 RWHP/510 TQ)
Member of 11sec. club &
NRA Benefactor Member
Old 09 Sep 2003, 02:01 am
so can this be done, or does the bar's bolts need to be tight?
Old 09 Sep 2003, 02:40 am
It will only take a few minutes to remove the nuts if you need to get to something under the bar. No big deal. Yes, the bar needs to be solidly mounted.
2003 Electric Blue GT. Mods - BTG lowering springs, Polished Blane hood struts and hatch strut covers, chrome door handle scratch guards, molded rear splash guards, BTG polished strut tower brace, BTG axle back exhaust, K&N drop in air filter with baffles removed, Royal Purple synthetic motor oil and K&N filter, Polished front and rear sill plates, Chrome \"PT CRUISER\" rear license plate frame, chrome door spear covers, Chrome antenna bezel, Get the BEST detail products from Gary here: http://www.perfectautofinish.com/
See my PT and mods here:
http://www.imagestation.com/album/?id=4289059783
MY EMAIL ADDRESS: stephenlarson@adelphia.net
Old 09 Sep 2003, 03:18 am
The whole idea of a strut brace is that it is solidly attached to the frame thru the strut tower and or other frame componets and keeps all of the front end parts in proper alignment. One reason they dont work well on some cars is that the suspension parts are so weakly attached via rubber bushings the bar can not do its job correctly!
Old 18 Aug 2009, 04:05 am
Charon's Avatar
Smile Re: pt-tuning strut bar mod ?
G'day all,
Punch why not check this out, may save you the trouble.
LINK:
Whiteline Strut Brace Quick Release Kit - ModYourCar.com - Car Accessories | Car Parts | Performance Parts | Aftermarket Parts
Cheers, Andrew...
Old 18 Aug 2009, 05:34 am
Default Re: pt-tuning strut bar mod ?
I don't think unbolting at the strut tower is a good idea - those bolts can't take much torque...
Look at a bar like this: (Scroll down)
PT Cruiser Performance Kit Number Two
Old 18 Aug 2009, 10:18 pm
soonercruiser's Avatar
Cool Re: pt-tuning strut bar mod ?
Doesn't make sense to me!
You're trying to stiffen up the front end. So, if it ain't stiff, it won't stiffen. All you'll get is more noise as the parts pop around.
Frank, aka SOONERCRUISER, and the Black Sheep
(Two Cruisers are better than one!)
Strut Nut Problem with BTG Tower Brace purplept Turbo Wheels/Suspension/Handling 9 09 Jul 2004 08:06 pm
January contest winners announced skylight General PT Cruiser Discussions 105 19 Feb 2004 02:39 am
Strut Tower Groan bigguigt Turbo Wheels/Suspension/Handling 20 15 Jan 2004 04:43 am
Pt Tuning strut brace DC2 Turbo Wheels/Suspension/Handling 1 16 Sep 2003 09:30 am
PT TUNING STRUT BAR IS AVAILABLE PTGT Redman Turbo Performance 12 08 Sep 2003 10:56 pm
  Myspace Layouts | Bob's Free Stuff Forum | Debt Consolidation | Cheat Codes | Download Anime
