Hey, I got a 06 GT PT over the summer, and was wondering what performance upgrades are recommended and what I can expect to pay and gain from them, also which are the easiest(easy, but beneficial)? (I have very little experience working on cars)
Thanks! |
Probably the Air box mod which will cost you a K&N drop in filter. Not sure on cost, $25 maybe? Search it out and you will find instructions.
New plugs and wires are a good idea as the factory wires are crap. Next Stage 1 which gives you 5hp and 15ftlbs of torque on the '06. $600, but is the building block for many more mods. Basically all that is invloved here is swapping out the pcm. Beyond that you will want a boost gauge, maybe wideband. Bigger exhaust, boost controllers, stiffer waste gate actuators, the posibilities are endless!!! Btw are you auto trans or 5spd? Go and check out PTCrew.com.
![]() LCG, please post photos of your PT!!! Oh, and...
Thanks for all the responses. I have the 5spd manual trans, with everything stock.
I'll get some pics up soon!
in the next post
Anismith Mercedes Benz Wheel |
one thing to do also is install a boost gauge then boost leak test.
buy a bag of zip ties and ziptie all you vacume lines go to home depo or lowes and buy a 2" plumming cap, get a valve stem from autozone and put it in the center of the cap, remove the intake and place on the turbo inlet and fill the system with air. take a bottle of soap and water and spray on various vac lines and look for air bubbles. a few places that will leak air is the factory PCV valve, go to the junk yard and pull a brake booster off a honda or nissan, or go to bwoodypreformance.com and buy one from the SRT-4, insert it on the vacume line between the intake manifold and PCV valve. another common place you will see a leak is a vacume line on the turbo to airbox (TTAB) pipe, remove that line and cap both ends.
Nevin. 03 SRT-4 — 132k mi ported stocker and lots of other stuff 68 Mustang Coupe — project fail!! PT Less - ex wife took in the divorce 3/2011 05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08 3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge |
| My car started jerking! | helene | Tech & Performance Forum | 14 | 30 Oct 2011 09:58 pm |
| 2004 GT started lurching while driving, engine light came on | Larndeb | General Turbo Discussions | 31 | 22 Apr 2011 08:05 pm |
| Started gas door mod | lowpt | Exterior Accessories Forum | 12 | 08 May 2009 10:30 pm |
| What I have started doing.. | ucantcme | General PT Cruiser Discussions | 22 | 18 Mar 2008 06:24 am |
| I started a Detailing Business! | TaylorMade | The Detail Shop | 18 | 01 Apr 2005 08:18 pm |
