Originally Posted by Mean Green
Most definitely makes a difference. I have seen the difference on the dyno. A 2-3 hp gain and double digit losses in torque. Here's some info. ISUPAGE; Performance Intake System Basics This second article has to do with a supercharger and a hot air intake, but pretty much the same difference. http://www.kennebell.net/techinfo/ge...AirWARNING.pdf
The stock airbox system is good until around 400 hp. Everybody has to make their own choice. Your system would probably be even better if you weren't sucking in hot engine air.
Clip from 1 of the articles;
It is, of course, your decision if you choose for your engine to suck in this hot underhood air with one of these over the counter or "custom" kits.
However, these things are not good for our superchargers and we not only don't recommend them, we are warning against the use of them. Look at
the facts. 10° of hotter air is equivalent to 1 psi of boost. That means the difference between the fenderwell ambient 70° system and the hot underhood
air temp can be an amazing 130° (200°-70°=130°) hotter. That 130° equates to about 13 psi of additional boost (13x10°=130°). So, you thought your
engine was only seeing the increased temperature of 100° from 10 psi boost (10x10°=100°).Wrong. It's 100°+130° or 230° plus the ambient. That's
the air temp of 23 psi boost! Surprised?Are you getting the picture yet?
Wow, 200* going into my intake. Maybe on a dyno under full boost with the hood closed and no fan in the front of the car. Never seen that on my car. I have a gauge the shows what the AIT(air intake temp) sensor sees sitting right in front of my face and the temp has never got that high or anywhere near that. Unless I am under boost the AIT sensor is no more the 14* above outside temp. On a turbo I would think that the compressor blades themselves (that this intake air flows through) would heat up the intake air from just the heat transfer through the turbo shaft even though we have 180* water/oil cooled bearings. Anybody ever took a thermal image or used an infrared thermometer to see the temp of the compressor blades? I don't believe everything I read without some proof. I have a Diablo that will data log sensors and tomorrow when it is mid 70* here in FL I will log at different speeds and also sitting still to see how long it takes for the temp to rise. I would try the same with the stock air box but don't have one so maybe someone else can do that.
2004 PT PLATINUM Lite
Auto | S1 | S2 injectors | K&N FIPK | Hexalogger | S2 wastegate controlled by PCM | 3"o2 | 3"cat | 3"DP | 2 1/4"catback | plastic intake | W/I | DSP Nemo/MM tune | Black ES MM Inserts |
13.89@100.96(1/2 tank E40 fuel, w/i, back seats and spare out, 17" street tires, DSP controlling S2 wastegate)
