Cold Air Intake
Old 09 Oct 2003, 04:37 am
Default Cold Air Intake
I ran a 2" hose from the opening to the left of the driver's side fog light up to the hole in the fenderwell for my intake. I took the silencer from inside the air box from my wifes '01 PT, cut it in half and cut part of the lip off so it would lay flat on the bottom. I then painted it Onyx Green so it would match my GT and slipped it over the hose. I think it added a nice finishing touch. I have the AMX1397 (Jim Barnes) intake. For those who have it you know that part of it is made from a metal pipe. Before I ran the 2" hose this pipe would be hot. Now, with the 2" hose, the pipe is ice cold to the touch. The air going through it is truly cold now. It may be seat of the pants, but I feel a quicker response and my GT is even more of a blast to drive.
Old 09 Oct 2003, 11:13 am
Interesting mod--well done. I think Jim did a similar thing with clothes dryer tubing. Exactly where did you mount the silencer to stabilize the hose--is it on top of the fender lining?
Thanks.
Light almond GT w/5 spd, aluminum gas cover, 400-watt amp w/Kenwood 3-ways in rear, EJECT power button, custom dual exhaust, hidden trailer hitch, mini-flames by Streamline, mini-flames around windshield washer, \"amx\" turbo-up custom intake, Stage 1, BTG strut tower brace, Eibach Pro-Kit Springs, Custom 17x7 wheels.
Old 09 Oct 2003, 12:07 pm
this mod was done by me, jim amx1397 in my o1 pt and the redone in my turbo and the 2" hose as i have put in the forum before, is 2" heater duct from pep boys
instructions::::
jack up drivers side front, remove front wheel.
remove screws or fasrters from the fender outside DO NOT REMOVE INTER FENDER just loosten it.
pull inter fender away enough to see where the heater duct goes thete is a path that it fits. cut the plastic near the fog lite where the hose can get the cold air. push and pull the inter fender back in place.. don't gorget to leave a 1" gap on top so water doed not get to the intake also take a screwdriver and at the lowest bend in the hose punch 2 or 3 holes so water can drain. I have been running this for three(3) years with no water getting to my intake JUST COLDER AIR
for the car not the money.
jim
Old 09 Oct 2003, 02:28 pm
I also did this the first week I had the car. It seems to help. Worth the time
Old 09 Oct 2003, 03:29 pm
umm your filters metal ring is very close to that battery cable, i dunno if this is a good idea.
punch
Old 09 Oct 2003, 03:35 pm
punch
That is the negative clamp. You can relax becuase it won't hurt a thing even if it does touch.
Old 09 Oct 2003, 11:41 pm
see bracket!! no move!! rubber el at turbo move!! no touch batt!!
amx1397 intake good!!!
jim
Old 10 Oct 2003, 03:56 am
Thanks.
That's the modified silencer you see next to the fog light. The hose is attached to the back of it. The modified silencer is painted Onyx green so it blends in......I got the idea from Jim. He told me about it when I got my intake from him. I finally got around to doing it.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 Oct 2003, 03:57 am
Right On! [?] I really like your intake.
F/S 3" AEM Cold Air Intake Bypass Valve AZ_IceMan Classifieds: For Sale/Trade 0 08 Aug 2005 06:06 am
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
2003 TURBO UP, COLD AIR INTAKE amx1397 Vendors & Buyers Forum 1 18 Nov 2003 05:39 am
Real cold air intake Airbillster Tech & Performance Forum 5 02 Sep 2003 02:26 am
A TRUE cold air intake Airbillster Turbo Performance 7 14 Aug 2003 01:19 pm
