b00st ?
Old 11 Feb 2010, 05:33 pm
Default b00st ?
so....got a problem. I slam on the gas and the boost shoots up to 15 and then down to 10 and then back up to 15 and then again to 10. it keeps doing this until I let out of the gas. what do ya'll think it is?
thanks in advance.
'03 GT Autotragic
Drag Stats!
•R/T .252
•1/8 Mile 9.644 @ 72.92
•1/4 Mile 15.009 @ 93.50
Mods!
•Intake Box Removed
•3"F 5"R Lowering (Thanks Candyman)
•19" ASA JH9 w/215/35/R19 General's
Traded (04-14-2010)
'06 Mustang GT Autotragic
Drag Stats!
•R/T 6.107 (Waiting on the wife's smart car to get a head start ;P)
•1/8 Mile 9.152 @ 78.36
•1/4 Mile 14.202 @ 96.69
Car Team Website:
Insufficient Boost [iB]
Old 12 Feb 2010, 10:34 am
ROCKETMAN8060's Avatar
Default Re: b00st ?
thanks in advance.
Maybey a leak! I have one on my intake that I have to fix this weekend and it does the same thing!
ROCKETMAN8060
Old 12 Feb 2010, 10:48 am
Default Re: b00st ?
That's what I was thinking - check all clamps.
Old 12 Feb 2010, 11:22 pm
ChefTank's Avatar
Default Re: b00st ?
thanks in advance.
is this all in the same gear? or does boost spike around 3500rpms and drop to 10psi the closer you get to redline?
i have never heard of a leak the opens and closes under consistant boost/vac.
what are your mods? stock gt's dont boost 15PSI (often) this info will help.
sounds like a stock wga doing what it is supposed to do to me... unless i misunderstood you.
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 13 Feb 2010, 01:46 pm
Default Re: b00st ?
Thanks for all the replies. I will check everything. I'm going to go out and get a video of me going from 1st through 3rd gear. Maybe that will help out on the diagnostics!
'03 GT Autotragic
Drag Stats!
•R/T .252
Mods!
•Intake Box Removed
Traded (04-14-2010)
Drag Stats!
Car Team Website:
Old 15 Feb 2010, 12:04 am
Default Re: b00st ?
'03 GT Autotragic
Drag Stats!
•R/T .252
Mods!
•Intake Box Removed
Traded (04-14-2010)
Drag Stats!
Car Team Website:
Old 15 Feb 2010, 12:17 am
xwing777's Avatar
Default Re: b00st ?
I can hear a whistle (not the normal turbo sound either) so i would check the line going to the boost gauge to engine for cracks. The plastic line that comes with the gauge gets brittle over time to.
Old 15 Feb 2010, 10:10 pm
ChefTank's Avatar
Default Re: b00st ?
the crusher couplings on the back of the guage can come loose real easy too. i say that because your guage doesn't appear to be in any type of a pod. even if it is 2 sided taped down the movement can cause it to come loose. my computer blows so i only watched the second video but it is not a boost leak. as xwing said i feel it is something in your guage line or connection. GL
Josh
50trim (2 Weeks)
Stage 3 (3 months)
Old 24 Feb 2010, 11:34 am
Default Re: b00st ?
Ok, I took a look at everything under the hood. Everything seems to be in the right spot. I haven't changed anything...and get this...the other day...I was driving down the road and it just works perfectly... didn't change a single thing...stupid chrysler
'03 GT Autotragic
Drag Stats!
•R/T .252
Mods!
•Intake Box Removed
Traded (04-14-2010)
Drag Stats!
Car Team Website:
