2004 2.4 turbo with dtc p0303 & p0300, 53K Miles
  • 1 Post By glsm95
Old 26 Feb 2010, 11:30 pm
golfkell's Avatar
Lightbulb 2004 2.4 turbo with dtc p0303 & p0300, 53K Miles
After receiving codes, 0303 & 0300, I replaced the original plugs and wires. I cleared the codes, but I continue to get 0300. Any recommendations? Ideas ? Coil or EGR / vacuum issue?
Old 27 Feb 2010, 02:09 am
Default Re: 2004 2.4 turbo with dtc p0303 & p0300, 53K Miles
Welcome to the forums.
You have no egr on an '04 turbo - did you mean PCV?
Coils rarely go.
Does it idle okay?
The wires are hard to seat at both ends - be sure they are seated well.
Old 27 Feb 2010, 08:33 am
From PT Do-It-Yourself.net:
A misfire code in a specific cylinder (P0301-Cylinder #1, P0302- Cylinder #2, etc.) usually indicates a possible problem with a plug or ignition wire. A P0300 code indicates the misfire is random and moving around from cylinder to cylinder. The cause here would likely be something that upsets the engine's air/fuel mixture, such as a major vacuum leak, or unusually low fuel pressure
Check around for that vacuum leak.
Old 27 Feb 2010, 11:28 am
golfkell's Avatar
Thanks for the insight. I'll follow-up later. Godspeed.
Old 27 Feb 2010, 02:14 pm
golfkell's Avatar
Idle is the problem. I purchased a PCV and will install after the engine cools a bit. Thanks for the input.
Old 27 Feb 2010, 06:53 pm
golfkell's Avatar
PVC changed and fuel injectors cleaned, but still have a rough idle. Will change the coil next.
Old 28 Feb 2010, 05:36 pm
golfkell's Avatar
Changed coil and battery, all is well.
Old 06 Feb 2016, 10:58 am
I have a 2003 with a p0300 code and can't find the problem mabe someone can give me a clue with it
Old 17 Mar 2019, 09:02 pm
Had same codes on my 04 turbo. Replaced plugs, wires, cam pos. sensor and crank pos. sensor with no luck. replaced intake manifold gasket and that fixed it.
Handy_Cruiser likes this.
Old 17 Mar 2019, 09:20 pm
Handy_Cruiser's Avatar
Welcome back to the forum!
help with P0303 diagnostic code jonesfam7 Tech & Performance Forum 2 22 Dec 2008 12:49 am
2004 Chrysler PT Cruiser!! For Sale, Low Miles! VanillaFantasy08 Classifieds: For Sale/Trade 3 28 Feb 2008 11:30 am
2004 PT Cruiser - Sport Wagon - very low miles (petaluma) $9900 skylight craigslist 0 20 Jul 2007 11:50 am
~~`~ 2004 Chrysler PT Cruiser (Limited Edition) Turbo ~~~ Low Miles!! (dublin / pleas skylight craigslist 0 09 Jul 2007 03:20 pm
2004 PT Cruiser Touring Edition 34K Miles Midnight Blue - $5000 Miami, FL sackz23 Classifieds: For Sale/Trade 6 05 Jun 2007 07:48 am
