BOV and PTB
Old 27 Feb 2010, 09:45 am
Kevhead's Avatar
Default BOV and PTB
Looking for some advice - I've installed the ST1 Wastegate Accuator, and with a little preload I'm getting a couple more pounds of boost (and it's holding the boost longer), which was my goal. I'm concerned about the Partial Throttle Boost though. A friend suggested that I add another BOV in line by splicing into the Charge air cooler-to-throttle body air intake duct. I have the MOPAR BOV in place, but was told that by adding another BOV along with the MOPAR (GReedy or similar brand with adjustable control), I could correct the imbalance and eliminate the surging. Does this sound correct?
Old 27 Feb 2010, 02:11 pm
Default Re: BOV and PTB
Do you mean the stage 2 wga? Do you have the stage 1 upgrade (stage 1 pcm)? What are you boosting? PTB is not suppose to be a problem with the S2 waga.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
