You got this...no vaccuum.
![]() 14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!! |
Twin, Saki is right. the gauge should read "0" with the engine off or even at an idle (boost only Gauge). There is an issue with that gauge. You might consider returning that gauge to the mfg or retail outlet where it was purchased, and spring for the difference and get a vac/boost gauge. This will be helpful in getting better gas mileage as well as triobleshooting vac problems (leaks etc..). I think that the issue with your gauge is that it is malfunctioning, not that it is the wrong kind.....
Make sure the gauge power is tapped into a fuse that remains on through start-up. If it doesn't your boost readings will be off. Needs a constant HOT source. I used fuse 10 for my boost gauge. If it is interrupted in start-up, your boost reading can be off by 5psi or more.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
PT-Dave 2003 Cranberry Turbo GT ![]() Stage I, custom 3\" exhaust & Cowl Intake, Mopar BOV, Dual gauge pod w/vac-boost & A/F meters, Hood Struts, Yokohama ES-100\'s Best 1/4 so far: 14.489 @ 93.65, best 1/8: 9.222 @ 74.261 |
I never realized this but there is an electrical boost gauge that uses a MAP like sensor and connects electrically to the gauge. I have never seen one, but I have heard comments on it on the boards. I looked @ twins pic of the gauge again, and I do think that it is a mechanical boost gauge and the gauge is malfunctioning..........
GearHead,
I have the gauges that you are talking about. I have the Cobalt Auto meter gauges. They are not Mech, but are all electric. My boost gauge has a map sensor, and we spent 2 days playing with it and it would not work. After a call to auto meter we found that what Redman was saying is right. It needed a constant hot power source. After that it worked fine. I currently have the Boost (With Vac), Oil Press, and Air Fuel gauges (need to get this one wired up soon). Being that they were not Mech gauges, it made running the lines a lot easier. If I can borrow my friends digital camera, I will show you where we mounted the map sensor and what they look like.
Black 03 Turbo \"Pirate Harley Cruiser\" Mopar Stage 1 and BOV Autometer Gauges in Triple Pod Custom Emblems Custom Switch Plate AirRaid CAI Chrome Gauge Eyelids FlameBall Shift Knob BTG Strut Tower Brace Dual Battery System 12 inch Black Shorty Antenna Working on Custom Audiobahn System Coming Soon Eibach Springs and Sway Bars. Plenty of Neon |
Here is my MAP sensor before wiring. There is a harness to the gauge with 5 wires ![]()
My bad. I didn't think about the possiblity of you having an electric gauge. Sorry.
| Boost Gauge tie in | GT Kruzr | Turbo Performance | 2 | 04 Apr 2004 02:13 am |
| boost gauge | DREAM2 | Turbo Performance | 5 | 16 Mar 2004 01:46 am |
| part numbers | Punch | General Turbo Discussions | 5 | 13 Jan 2004 11:46 pm |
| Final manual boost controller installation | Ian-PT-GT | Turbo Performance | 83 | 10 Jul 2003 11:57 pm |
| Boost gauge install question | NorthernPT | Turbo Performance | 14 | 21 Apr 2003 11:35 pm |
