150 miles to a tank of gas?
Old 25 Mar 2010, 11:32 am
realityrunner's Avatar
Send a message via AIM to realityrunner Send a message via Yahoo to realityrunner
Exclamation 150 miles to a tank of gas?
I have a 2003 Turbo GT that currently has a little over 123,000 miles on it, recently the car started to make hideous noises so I took it to a mechanic who told me an oil tube leading to my turbo got plugged up over time and essentially burnt the turbo out, I had also noticed the trip odometer reading 150-160 miles when I filled up at a gas station with a low gas light on. Speaking of, when the low gas light comes on the car only ever takes 10.??? gallons of gas.
I opted to have the turbo rebuilt since the car is so old. Got the car back a week ago and it runs fantastic...except I just filled up this morning and noticed my trip odometer read 155 miles with a low gas light on. Doing some Googling lead to several "solutions" on these forums such as bad wiring/sensors which supposedly runs $1000, speeding in the car to "blow it out" (whatever that means?), and simply trying to disconnect the battery to reset the cars computer.
I know nothing about cars and most mechanics just say: "Oh well those Turbos sure do suck gas!" It just doesn't make since to me since I had a 2003 Ram 1500 "Rumble Bee" that got about 225 per tank.
Old 26 Mar 2010, 08:53 am
Default Re: 150 miles to a tank of gas?
Welcome to the forums.
If you driving is stop-n-go, you'll get lousy mileage.
use search and read - tire pressure is the easiest thing you can do to improve mileage.
At 123,000 miles, I hope you've had the timing belt replaced.
Old 26 Mar 2010, 09:26 am
Have you had regular maintenance on the PT? Plugs and wires changed? Air filter checked? 02 sensors replaced? I take it you aren't using synthetic oil. The probably prevented the oil tube from getting clogged up. Do you know your supposed to let the engine/turbo cool down after a run? That alone might have stopped the line clogging even after using conventional oil.
Like QSD noted, air pressure, and stop & go driving will kill mileage on a car that doesn't do well in the first place.
Old 26 Mar 2010, 10:36 am
IMIEIW's Avatar
Send a message via AIM to IMIEIW
That was a surprise to me too. My first fill up got me about 16 MPG. I checked the tires and added air and drove a little more conservative, last two tanks yielded 19 +. I can live with that.
Old 21 Apr 2010, 09:19 pm
CYCLONE_06's Avatar
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
See I have an 03 too. I changed the plugs n wires, re gapped them to .030 and changed my tires to 215/50/17s and this last time, so far, ive gotten 125 miles out of a quarter of a tank. Best mileage run so far.
~CYCLONE_06
"It's been said winning isn't everything... Just not by me."
--Mark Martin
Old 22 Apr 2010, 02:55 pm
IMIEIW's Avatar
Now that the Cruiser is getting used to the way I drive and using premium I am now getting close to 22mpg. This is a marked improvement over the first couple of tanks. Check your air pressure too.
Old 22 Apr 2010, 04:35 pm
~CYCLONE_06
Don't believe for a minute that you'll get 125 per 1/4 tank. The gas always seems to last longer the first 1/2 of the tank. It5's the 2nd half that goes quick.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 23 Apr 2010, 07:33 pm
Dino's Avatar
I wonder why that is? I often wondered why that happens. I even went on fuelly.com and did some research and it seemed like to me, that people that filled up with half a tank or more were logging better gas mileage. You would think the extra weight of the fuel should if anything take away a slight bit of mileage.
holycats's Avatar
Originally Posted by realityrunner View Post
...low gas light on. Speaking of, when the low gas light comes on the car only ever takes 10.??? gallons of gas.
[snip] ... It just doesn't make since to me since I had a 2003 Ram 1500 "Rumble Bee" that got about 225 per tank.
The same thing just happened to me, fuel light came on, and it only took 10 gallons. I have yet to figure out when I'm 'really' low on gas - but better safe than hitchiking!
Also - it's pretty hard to compare 'tankfuls' if the vehicles have different size tanks.
Black 2005 GT w/AT
Old 24 Apr 2010, 11:54 am
Absolutely true. The top "half" is more like two thirds. The gauge isn't linear.
The gas tank.. ucantcme General PT Cruiser Discussions 47 22 Aug 2016 11:01 pm
I'm only getting 120Miles to a tank.... rubsnick General PT Cruiser Discussions 20 03 Oct 2009 09:02 pm
Vaccuum Tank?? notadodge Tech & Performance Forum 5 09 Mar 2008 11:27 am
Gas tank leak asaccoma General Turbo Discussions 7 26 Dec 2007 09:54 pm
Gas Tank BruisersCruiser General PT Cruiser Discussions 5 14 May 2004 04:42 pm
