Compression; Continuation of P0304 Misfire
Old 04 Apr 2010, 05:51 pm
Default Compression; Continuation of P0304 Misfire
I've had a P0304 cylinder #4 misfire for 3 mos now and have replaced plugs, wires, coil, upper intake manifold gasket and injector.... Idles a little rough here and there but runs great otherwise....
Just did a compression test; All cylinders are about 120pso except #4 which is 135psi...
What does that mean???
Thanks, Duff
Old 05 Apr 2010, 09:16 pm
Default Re: Compression; Continuation of P0304 Misfire
mine was the lower intake gasket on #4, most prone to go out. the upper was fine, but replaced it as well. On the #4 runner, it was missing a chunk.
2003 PT Cruiser GT- 15psi, 3" TTAB pipe, K&N drop-in, 3" downpipe, 3" downpipe back exhaust, tokico blues, boost gauge....breaking loose at 50mph
Old 06 Apr 2010, 09:05 am
It means your problem is not valves or rings - that all your cylinders are just a little over being withing 10% of each other is a good thing.
Lower intake gasket is next logical target.
Spray starting fluid along intake seam - if idle smooths out, that confirms gasket.
Here's another with Lower gasket.
some PT GT problems Hesitation
Old 09 Apr 2010, 12:39 pm
I sprayed along the top of the intake; hard to get to the bottom gasket...NO change...
HOWEVER, when I sprayed the valve cover gasket (was changed a month ago), it choked and cut off????
What the heck is going on. How did that happen. I did NOT hit the electrical connection. Sprayed it at the #4 end of the valve cover.
Any suggestions other than retorqueing the vavle covers which I should have done a week after I changed it...
Thanks
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
P0304 question 4SPEED Tech & Performance Forum 4 12 Apr 2008 04:51 pm
engine low on compression LoWandSloW Tech & Performance Forum 7 02 Jul 2007 09:58 am
compression fittings Punch Exterior & Interior Styling 10 11 Nov 2003 10:36 pm
compression fittings? Punch General PT Cruiser Discussions 4 02 Oct 2003 12:59 pm
