Problem or just turbo?
Old 26 Apr 2010, 12:44 pm
Default Problem or just turbo?
I dont know how turbo cars are supposed to act, so i dont know if this is normal or not:
When i first start it up, i put it in drive and gradually give it throttle. The motor sounds like im revving it up. I will be giving it steady low throttle, but the rpms will be going up and down, almost back to an idle. This seems less noticeable once it warms up. When it is doing this, i can get on it decently hard, and after a slight hesitation, it will accelerate smoothly. It does this in first and second gear as long as i am barely giving it throttle and the rpms are under about 1800.
All i need is someone that also has a pt gt automatic that can tell me if theres also does this, or if i should check it out further.
Thanks
HELP: Turbo Bearing Problem LaP Turbo Performance 2 09 Nov 2009 08:16 am
Help! 2003 Turbo Engine problem! henroid2 General Turbo Discussions 8 03 Mar 2008 04:13 pm
Turbo problem solved hifiman General Turbo Discussions 2 17 Jun 2005 07:27 am
Please help with turbo problem hifiman General Turbo Discussions 4 16 Jun 2005 02:43 pm
Turbo Timer Problem sakigt Turbo Performance 0 06 Jul 2003 03:56 pm
