Blow off plate issue...
Old 07 May 2010, 09:36 pm
Default Blow off plate issue...
Alright well I'm sure most of you know that installing the BOV from mopar is a real PITA... well the farthest bolt was rusted, so we tried working it in and out to relieve some of the rust... and it busted off inside. Eitherway we got the surge gate off, and put the BOV on with two bolts and there was a slight gap on the third hole like 1-2 mm... it sounded like a supercharger/a dying cat. So after realizing that getting that turbo off is more trouble than it's worth, we went and got some high temp RTV and loaded it... it now sounds like a normal turbo but there's no blow off sound... What would you guys recommend?
Old 07 May 2010, 09:49 pm
Default Re: Blow off plate issue...
Start saving your money for a new motor/turbo cause you need the bov to be working. You really messed up. I would not drive it that way.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 08 May 2010, 08:07 am
Yeah I know lol aluminum and steel just don't mix =\ I'm gonna see if I can try to bring it somewhere so they can drill it and tap it out
Old 10 May 2010, 08:42 am
Had the same thing happen to me, had the friend pull the turbo, drill and tap it and all is good now. He said pulling it wasnt hard at all.
-------------------2003 Pt Cruiser Turbo 57k miles-------------------
Old 10 May 2010, 03:49 pm
nevinsrt's Avatar
pulling the turbo off on a PT is alot easier then the lack of room on a Neon.
3- 16mm, 2- 8mm, 1- 10mm, and one worm grove clamp and the turbo comes off.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 22 May 2010, 02:24 pm
Yeah haha I actually just pulled it myself, the guy I spoke to told me I'd have to drop the engine a few inches to get to it but other than that it was pretty easy. I did that the same time I upgraded the injectors and CAI so everything was already apart. My friends also convinced me to do this, at first I thought it was dumb but I think I'm gonna leave it after trying it for a few days:
The other side I had to move all "cruiser" to the right about an inch to accommodate the larger GT lettering.
blow off valve SuperGirl Tech & Performance Forum 24 25 Apr 2013 07:57 pm
Mopar Performance Blow off plate IMIEIW Turbo Performance 7 13 May 2010 06:06 pm
what is a blow off valve careyk General PT Cruiser Discussions 3 17 Apr 2008 01:23 pm
Blow Off Valve Conversion Kit gonzomania Tech & Performance Forum 10 08 Sep 2004 09:08 am
...oil blow-by catch can? earringboy Turbo Performance 21 05 Oct 2003 09:04 am
