Which cold air intake did you choose?
Old 22 May 2010, 02:29 pm
Default Which cold air intake did you choose?
Well I'm just curious about which CAI is the most popular... I choose S&B because I like the "under glass look" that it has, and it filters out more dirt than the slightly less expensive AFE CAI... Plus the re-charge kit is so much easier to use since they give you the "precision" kit. Plus, I like less popular brands, don't get me wrong, K&N makes good stuff I just see way too many cars with their stickers on them.
Old 22 May 2010, 04:21 pm
Wumpus's Avatar
Send a message via Yahoo to Wumpus
Default Re: Which cold air intake did you choose?
After reading alot about the intakes here and on ptcrew, I went with the airbox mod and a K&N filter. So far 10,000 miles on it and loving it. No complaints at all.
The big issue with it was that the cold air intakes are mostly taking air from the engine compartment. That air is a lot warmer than the air that it is sucking in from the tire well.
I'll leave you to do your own research on it, but the airbox mod worked best for me.
-Wumpus
Old 22 May 2010, 04:41 pm
-Wumpus
Excellent choice.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 24 May 2010, 01:12 am
I'm running the K&N FIPK, which includes a heatshield. Not sure how effective the heatshield is but I like the way the car sounds with the open filter!!!
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 26 May 2010, 11:36 am
Airbox mod for me. I do own an Airraid that I put on sometimes because I like to hear to turbo whine more. I chose it because it forms a seal against the bottom of the hood that keeps out the hot engine air. I have also plumbed intake air from the front facia to a port I created with fiberglass in the bottom of the airbox.
Old 28 May 2010, 04:12 pm
I went with the TTAB Hardpipe with Airbox Mod
Car Definitely pulls harder (according to butt dyno), Got better gas mileage, and can hear the turbo spool better :-)
Old 28 May 2010, 07:31 pm
AirAid intake. I drive 68 on the x ways and have gotten what I think very good avg mileage. Sounds good also, I believe that I get 2-3 MPG more with it.
Old 28 May 2010, 08:03 pm
Get your butt dyno recalibrated.
Oh boy, another "better gas mileage". Would you please explain how a bit more air gives better mpg.
Old 29 May 2010, 07:21 am
For me, as I track every gas fill up, my numbers show it for the same kind of driving in the same conditions.
Old 29 May 2010, 12:48 pm
That's quite simple ... 1. The factory TTAB is very restrictive! which means the engine is having a little trouble breathing. by opening it up, More air flow, allows the engine to breath better, More Air, provides more Power, thus more efficiency since it doesn't need to work as hard. Think of it as getting one of those Tiny Red Duncan Donuts straw and trying to blow in. It'll be difficult but manageable. Then take the straws from McD or BK that's used in soft drinks and you find your self sucking a lot more air.
2. See my SIGGIE!!!
I track my fuel economy in not only a book but fuelly as well. and gas mileage went up after installing the TTAB Hard Pipe. I actually drive worse now then before just so I can hear the turbo spool and bov go woooosh
Also, if you look at the history... I never broke 19.7MPG prior to installing it.
Nuff Said
Cold Air Intake - Please look SlowwCory Tech & Performance Forum 4 19 Aug 2009 07:31 pm
APC cold air intake DIYPTGUY General PT Cruiser Discussions 9 18 Nov 2008 12:59 am
Cold Air Intake..? morrises Tech & Performance Forum 11 15 Jun 2008 01:20 am
BTG Cold Air Intake ptcruzin42 Classifieds: For Sale/Trade 2 08 Aug 2003 10:06 am
Cold Air Intake CREWZIN Tech & Performance Forum 11 25 Dec 2001 01:50 pm
