DROP IN PERFORMANCE FILTER vs. AIRADE GT TURBO??
Old 18 Jul 2010, 08:25 am
mjb457's Avatar
Default DROP IN PERFORMANCE FILTER vs. AIRADE GT TURBO??
Any noticable performance difference??mjb
Old 18 Jul 2010, 09:46 pm
VNT's Avatar
VNT VNT is offline
Default Re: DROP IN PERFORMANCE FILTER vs. AIRADE GT TURBO??
I like the stock air box since your not sucking Hot air.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 19 Jul 2010, 05:51 am
Neither does Airaid filter.
Old 19 Jul 2010, 10:24 am
Depends what you want. Stock box is supposed to give more power, Airaid, etc., I believe gives better mileage.
Both are better than stock.
Old 19 Jul 2010, 09:05 pm
ChefTank's Avatar
s&b, airaide, apollo k&n, etc as long as it is enclosed.
even the short ram systems show whp gains but torque loss. it is a matter of what you want or if your into looks. last time i dynoed i had 25xwhp and 300+wtq... i dont need more tq that the stock airbox will provide i want the extra whp for my topend.
you guys can argue till your blue in the face (some will) but the long tube runners on the intake manifold (plastic and aluminum) were designed to make more torque than the srt4neon due to the fact the pt is much heavier and needs help to get moving... do you want wtq or whp? there is you answer.
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 21 Jul 2010, 09:34 am
nevinsrt's Avatar
drop in filter with norkle and silencer removal and TTAB pipe and your set. best intake out there. closed so no hot air gets in.
me i make enought tq so i have a pipe with filter
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
K & N drop in filter for 01-04 non turbo mjb457 Classifieds: For Sale/Trade 0 19 Jul 2007 07:58 pm
{K&N DROP IN }OR AIRADE air intakke system?? mjb457 Tech & Performance Forum 5 17 Oct 2005 08:24 pm
K&N Drop in filter KingKole02 Tech & Performance Forum 27 01 Jul 2005 07:38 am
K&N Filter Drop-in....... CBurgerjr Tech & Performance Forum 4 26 Jul 2004 11:22 am
Drop in filter K&N Grossman Tech & Performance Forum 3 04 Feb 2004 11:58 am
