installing a turbo timer
Old 22 Jul 2010, 12:08 am
Default installing a turbo timer
i just bought a apexi penn turbo timer and i have a turbo 2005 gt pt cruiser and i need help hooking it up so i dont screw up wires and the car. if anyone knows how to hook this up please help. thanks
Old 24 Sep 2010, 01:42 am
Default Re: installing a turbo timer
Hey there guys after alot of time reasearching how to install turbo timers etc, i could not come up with and DIY instructions for an Apexi Full Auto timer for N/A & Turbo, i have had the timer sitting on my garage wall of parts for a while and since there was no DIY instructions anywhere for this timer on R33 i was affaid to install it. Anyhow 2 months later, i have decided to just go for it.
So, this is a tutorial for how to install a Apexi full Auto timer for N/A & Turbo.
The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
The Auto Timer stands as a technological marvel. The pen shaped, compact size makes the Auto Timer one of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi angle joystick button allows easy navigation through the many feature menus.
Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of after idling time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate as racing air/fuel ratio monitors. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage. To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
by (h@me)
Old 27 Sep 2010, 11:42 am
Or you can just run synth oil instead of dino oil and save yourself a lot of hassle.
Turbo timers are really an answer to a question that isn't being asked anymore on most street turbo cars.
Old 29 Sep 2010, 04:01 am
chris15's Avatar
Plus, they're a bitch to get to work with our cars.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
turbo timer GTcruiserkilla Interior Accessories Forum 1 27 Jul 2010 01:18 pm
Turbo Timer Mr.Blonde General Turbo Discussions 66 24 Aug 2003 09:45 pm
Turbo Timer .... onedivinehammer Turbo Performance 19 08 Aug 2003 05:59 pm
Turbo timer Lord Vadr General Turbo Discussions 14 03 Jun 2003 10:24 pm
Turbo Timer PK Cruiser Turbo Performance 2 15 Apr 2003 09:40 pm
