Boost hose blow out, w/ amx1397 mod
Old 11 Nov 2003, 09:25 pm
Default Boost hose blow out, w/ amx1397 mod
As some of you have heard I run 17 to 18 lbs of boost on the street, and I do. you could blow out this hose (97.00) for a new one. that hose gets as big as a loaf of bread with high boost.
when you disconnect the hose mod, if you connect a guage to that port you will find the boost in that hose before the throdle body gets as high as 27 lbs. If you go under your car, on the pass.side, where the hose from the turbo to the intercooler, it almost touches the body of the car, feel that spot, see if it is softer than other parts of the hose if you have high boost that hose at that point will feel like it has a soft or week spot in it. I wraped mine with a 3" heater hose, and wire tied it, so it can no longer rub. some times i don't say things as clear as i think them so if any of you are not sure what I am saying. e-mail me or call me I will be happy to help. amx1397@aol.com 954 336-3405 ft laduerdale fla.
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
boost controller for less than $10. how to make it bluebluegt Turbo Performance 6 20 Nov 2004 01:36 am
Taking control of the boost Jason_L Turbo Performance 2 03 Jan 2004 10:35 pm
20lbs of boost and no eng lite amx1397 Turbo Performance 6 21 Jun 2003 07:20 pm
