I installed the BTG intake a week or so ago, tonight I heard a high piched whistle coming from the engine. It only did it at WOT and happen for the first tonight. When I got home I popped the hood to see if any lines disconnected. Everything connected. Has anyone with the BTG or any aftermarket intake have this sound?
Not sure if this is related, but I noticed a high pitched whistling when I did a mod to my PT's intake. I revoved the silencers and drilled four holes through the fender wall just under the intake. Next day on a cold morning commute I noticed a high pitched whistle coming from the engine compartment. Checked it out, figured it had to be because of the wire mesh covering the holes in the wheel well. The whistle stopped and I have not heard it since. Reading your post I thought it might be from modifying the intake. Just a thought.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold. Mods On The Way: AGP Wastegate Actuator |
If you search around on the site you'll find a few posts on this one. Some of them are from me
. That gents is the turbo making its magic.Some can live with it other's can't. I actually like it now...But was uneasy at first. The noise should be audible as you approach 4000 RPM and get progressively louder until 6000 RPM (or until you shift). It should be loud enough to be noticed from inside the cabin with the windows rolled up but should not drown out a conversation. If it is much louder check your connections to the intake and make sure that you have a good fit around the turbo. If all is snug then you should be fine.
![]() -------- 2003 Silver GT PT Cruiser 3rd Brk cling, APC GEN2 Eurotails. BTG Intake. StreetGlow Gold Series underglow kit \"Green\". BTG Strut tower Brace. |
nbr10, I know with an intake you can hear the turbo spooling up but this was a different sound. It was like there was a Picollo Pete in my engine. Didn't go WOT on the commute in this morning, maybe I'll get a chance later.
R_K_GT \'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come..... |
If the noise you are discribing is similar to air being blown over a pop bottle then we are talking about the same noise.
If you put the stock airbox and silencers back in the noise will be all but gone. Then start to remove the silencers one at a time and you will see the noise gets louder. Then when you remove the Plastic pipe that runs from the turbo to the airbox you will see the biggest increase in noise. There is a HUGE Silencer in that pipe. If you want further proof remove all of the piping and leave the turbo open. WARNING: Do not drive like this. Then start the engine and rev it. you will hear the same noise (granted it is much louder under load) There is another high pitched noise which can occur if there is a kink in the breather hose that runs from the intake to the valve cover. This sounds more like a high pitched chirp which occurs at about 2 second intervals. This sound will happen whenever the engine is running though. Hope this helps to ease your mind
thanks nbr10
I've been meaning to ask this same question. At WOT as I am pushing past 4000rpm the sound changes from the whooshing of the turbo and I get this high pitched sound...this freaked me out, as I wasn't sure it was supposed to be there (I have never owned a turbo vehicle inthe past). It's been doing that as long as I've had the car, before Stage 1...
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
With stock boost settings this noise will NOT be nearly as noticeable. The pt with upped boost will drown out the turbo sound of other stock turbo cars or even lightly modded ones. This sound is gorgeous and music to any turbo enthusiasts ear...just sit back and watch the honda boys stare.
My Cruiser is slow. I love the law. |
only at WOT can i hear this very high pitched noise and it starts at very low rpm ! It is just my turbo making power and it is a product of my K&N typhoon intake! After testing a stage 1 at the black party I know the stage 1 is faster than mine but not by much!!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Thats the beautiful sound of the turbo spoolin!
Oh yeah!!!!!!!!
![]() E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip. |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| high pitched whine | triggerman | Sound and Security Forum | 7 | 12 Sep 2006 04:37 pm |
| High Pitched Squeak | SFsGT03 | Turbo Wheels/Suspension/Handling | 2 | 08 Nov 2003 06:37 pm |
| High RPM Miss potential Fix | Exhaust Depot | Turbo Performance | 11 | 15 May 2003 06:31 pm |
