p0304 code
Old 12 Dec 2010, 06:28 pm
Default p0304 code
Took the wife's car in to our mechanic last week. Service engine light on. This code is for a misfire on #4. Here is what he did.
removed intake
replaced plugs and wires
cleared fault code
installed new coil
missfire still present
removed intake again and ohms test fuel injectors
no problem found with injectors
Now he's telling us to go to the dealer. Any ideas anyone? Thanks, Jay
Old 12 Dec 2010, 07:13 pm
Default Re: p0304 code
He did ok except for changing out your coil. Everything else was a good shot at clearing the code. The one thing he didn't do was test for a vacuum leak around the edges of the upper manifold near the No#4 cylinder. The firing order from front to back is #1-#3-#4-#2.
Old 13 Dec 2010, 09:03 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
removed intake
cleared fault code
installed new coil
is this car a turbo or non turbo? if it's a turbo they are notorious for the gasket to leak. local parts store should stock it.
if it's a non turbo, i'd order a new set of rubber gaskets for the upper manifold at the dealer.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 14 Dec 2010, 12:23 am
Thanks, I hope a leaky manifold gasket will turn out to be the problem. My mechanic didn't say if he replaced the gasket when he took off the manifold. I just thought he would have. Jay
Old 15 Dec 2010, 11:28 am
Manual doesn't call for gasket to be replaced...
I assume you are NOT a turbo, because there is no need to take off manifold to do plugs & wires on a turbo...
Missfire causes - in order
Plugs & wires - swap the wire - see if problem moves...
Intake manifold gasket - usually causes a rough idle - spray WD-40 or ingnition fluid along intake manifold seams - if idle smooths out, it's a definite intake gasket failure.
Faulty injector - swap injector with another cylinder, see if problem moves
Coil - usually causes at least 2 cylinders to not fire.
low compression - valve or ring problem... - quite rare.
Old 15 Dec 2010, 05:58 pm
Thank you for the help with my problem. This is a turbo-lite model. My mechanic said that the intake manifold had to be removed to change plugs so I thought he knew what he was talking about. Haven't had a chance to ask him if he replaced gasket. I'm thinking probably not since it wasn't listed on receipt. I will try spraying wd 40 on edges of intake.
This rough idle only seems to occur after the engine is warm and in Drive at idle. Car accelerates well and no problems other than at idle which is intermittent.
Thanks everyone and I will let you know what I find out with the manifold test.
Old 04 Jan 2013, 05:56 pm
I just posted on my results with same problems except mine was at all speeds, not just idle, wondering if you bought same aftermarket coil I did.
'03 GT 105K
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
Check engine code P0304 Gary Mick Tech & Performance Forum 28 04 May 2014 06:26 pm
P0304 Cleared... duffner Turbo Performance 10 04 Feb 2014 11:26 pm
P0304 code Engine Light On wedge22 Tech & Performance Forum 1 23 Feb 2010 07:02 am
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
