No power
Old 23 Dec 2010, 01:47 pm
Default No power
05 PT
checked fuel pressure,exhaust,timming all ok
New to turbos when does the turbo kick in?
When and what line does vacum actuate the turbo.
Sure could use some help on this one.
Thanks
Old 23 Dec 2010, 04:18 pm
Default Re: No power
Turbo kicks in, a little, as early as 1500rpm, and gets stronger from there, but feels strongest at about 2400+rpm. The turbo is activated by exhaust pressure. When the exhaust pressure gets strong enough to spin the propeller of the turbo, it kicks in.
If there is no engine light, or no misfire, then you should start by checking for boost leaks.
Old 25 Dec 2010, 01:47 pm
tryingbe's Avatar
There is a sticker under the hood that tells you what vacuum lines goes where.
85 GLH
Watch out for anchor engine mounts!!
Old 25 Dec 2010, 11:06 pm
Or I have all the maintenance manuals in PDF format, if you want one let me know....
Old 26 Dec 2010, 02:03 pm
Sounds like an intercooler hose may have come off or leaking enough to affect performance. The crappy worm drive hose clamps on the IC hoses should be replaced with T bolt clamps. All vaccum lines should be zip tied to prevent leaks.
Old 27 Dec 2010, 03:04 pm
Agree, one of the presure lines in the turbo/intercooler/throttlebody assembly probably has a leak, just start at the turbo and tighten all of the clamps. You may even find one that has blown off. Better yet, replace them with T-bolt clamps.
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
No Power at all. kgreene Tech & Performance Forum 5 07 Jun 2010 03:24 pm
a little more power maybe? 026TB4U Turbo Performance 8 16 Mar 2004 01:24 am
PT Power..... studymunguy General PT Cruiser Discussions 20 02 Dec 2003 01:38 am
A/C Power Mel K Turbo Performance 9 05 Nov 2003 05:34 am
