'o4 Turbo bypass?
Old 14 Jan 2011, 02:00 pm
Default 'o4 Turbo bypass?
The bearings in the turbo are bad and grinding....can the turbo be by-passed?
I know I'll lose performance, but I'm on a fixed income and can't afford a new turbo at this time.
Old 14 Jan 2011, 02:51 pm
Default Re: 'o4 Turbo bypass?
Welcome to the forums.
The answer is, not easily.
Read this:
PTCrew.com - Learn it or Burn it.
Old 14 Jan 2011, 09:52 pm
Bet you talked to the dealer and got quoted for something like $1500+. You can get a used turbo off of ebay or from someone parting out a turbo. The Neon SRT-4 turbo is the same as the PT. A used one is usually around $300.
Old 24 Jan 2011, 01:20 pm
I got mine rebuilt at turbosunleashed.com
They are very friendly and do good work. You will have to change the oil line as well with most rebuilds to get a warranty on it.
Mine cost $410 with shipping and all.
No telling what you will get when purchasing a used one.
Old 24 Jan 2011, 01:24 pm
I agree with PTCT, there are a few good shops out there that do nice rebuilds, I've not heard of the one he's mentioned but I'm sure you can find one that will work with you. I do know that the longer you run that thing you are gambling at a huge implosion. You're going to wing something down that intake off the turbine and vaboom it goes.
Old 24 Jan 2011, 04:10 pm
Kawizx9r's Avatar
Not to step on toes but I've found some even cheaper w/o even trying.
SRT forums are the best place too look (they have regional sections). Look for a more local-SRT forum as well, they're everywhere! I've seen turbo's with zero shaft play and perfect running condition easily go for $150-250.
Kawi is a friggin genius!
Old 02 Feb 2011, 02:29 pm
Chris_TurbosUnleashed's Avatar
We do not recommend trying to bypass the turbo. No matter what you do exhaust will still travel past the turbine wheel causing it to spin. Eventually the turbine wheel could shear off and will do irrepairable damage to the exhaust manifold contour. If this happens you will have to replace both the turbo and exhaust manifold. A new exhaust manifold is almost twice as much to replace as the turbo. Aftermarket Turbo replacement is rather reasonable compared to dealership prices. See photos and info posted in our album section.
http://www.ptcruiserlinks.com/forum/...albums229.html
Chris-TU
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
ByPass Turbo? geeman44 General Turbo Discussions 3 16 Aug 2010 12:34 pm
map sensor bypass JaviPTGT General Turbo Discussions 8 10 Mar 2009 02:11 am
Bypass the cat? MINIHEMI46 Turbo Performance 11 22 Apr 2008 11:52 am
what does the mopar BOV PLATE sound like-does it bypass the purge valve completly ? mino Turbo Performance 1 15 Oct 2007 02:21 pm
F/S 3" AEM Cold Air Intake Bypass Valve AZ_IceMan Classifieds: For Sale/Trade 0 08 Aug 2005 06:06 am
