41te with a TD06
Old 20 Jan 2011, 10:21 am
SilverSleeper's Avatar
Default 41te with a TD06
I was wondering if the autostick tranny (300whp rated) could support this turbo
LCR Stage 3 Clone Kit - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
If I ran low boost, my goal bc of the tranny is about 250-260whp
03 GT: Mopar S1,DSP 93 Oct Tune,Composite Manifold,AMX UHP & LHP,Needswings DP with 3" Cutout,AEM Intake Into Modded Stock Air Box,Mopar BOV,Triple Pillar Pod Setup ( Boost Controller,Wideband,Oil Press),Rota Boost 17" Gunmetal Metallic,Nexen N 3000 Tires,Eibach Lowering Spring Kit W/ Tockico Shocks And Struts,HID's,Blacked Out Tail Lights.
( Awaiting Installation: AGP DogBone MM,GodSpeed FMIC )
Old 20 Jan 2011, 01:25 pm
Default Re: 41te with a TD06
A big emphatic NO! The 41TE sometimes has trouble with only 150 hp. Been there before. When they came out with the Stage kits they were going to come out with a Stage 2 for the PT turbo, but didn't because the 41TE can't handle the power. You could try to upgrade the tranny as others have when running more power, but I know of a couple of trannys that failed even then. Still, if you are up for the challenge then go for it.
Old 18 Feb 2011, 08:59 pm
The TD06 is rather big and probably MAJOR overkill for the tranny, I might just downsize to a Delta 38 or something along that lines @ low boost until I can swap out the tranny for a stronger one
Old 23 Feb 2011, 09:32 pm
ChefTank's Avatar
Big turbos at low boost is pointless. Its like eating a glass of milk with a spoon.
A forward motion e1 or ptp s3k will get your goal on 15-18psi easy.
Kevin (ourptgt) ran a e1 on an atx and now runs a stage3 on an atx w/ beefy internals. Search the crew, its all there.
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
41TE Upgrade SilverSleeper Turbo Performance 10 29 Aug 2013 05:21 pm
41te question b1gW00d Tech & Performance Forum 3 28 Jan 2010 07:09 pm
41TE Upgrade Kit SilverSleeper General Turbo Discussions 6 17 Dec 2009 10:27 pm
41TE Trans. Solenoid Pack, I have 2 part #s??? sknight88 Tech & Performance Forum 10 16 Nov 2008 04:49 pm
41TE torque rating twallyf Tech & Performance Forum 5 28 Jul 2004 10:13 am
