HORNS
Old 16 Mar 2011, 09:04 pm
tjc tjc is offline
Talking HORNS
Is there any other way you can mount the car horns? Can you mount one on each side?
Old 16 Mar 2011, 09:22 pm
Default Re: HORNS
Why would you want to? Are you looking for more room in the wheel well? A fast answer would be that, with enough wire you can mount them together or separately anyplace you darn well feel like it, but again why?
Old 16 Mar 2011, 10:33 pm
Default Re: HORNS
I have four horns mounted on my PT. The original, two chromes in the engine bay, and a Wolo Badboy airhorn up front. When I honk, people almost stop...lol....
If you are going to add horns, you need to add them through a relay or you'll burn out the horn ring in your steering wheel. One of the weak points in a PT. Mine all run through relays, works great.
air horns jacquesfrosty Exterior Accessories Forum 5 05 Dec 2010 09:09 pm
hella horns dbraveman General Turbo Discussions 29 21 Apr 2010 10:28 pm
Air horns and OEM horns? At the same time? DJmart Tech & Performance Forum 12 29 Dec 2007 09:31 pm
Horns? KingKole02 General PT Cruiser Discussions 1 05 Oct 2004 01:38 pm
Horns turbomangt General PT Cruiser Discussions 12 25 Sep 2003 03:18 pm
