PT Cruiser Forum Car Videos
Custom Wheels
Catch Can Really Works!
  #11 (permalink)
Old 17 Dec 2003, 05:58 pm
PianT PianT is offline
Am I right in thinking I don't need a catch can on the stock air box set up?
PianT
  #12 (permalink)
Old 17 Dec 2003, 07:31 pm
Punch Punch is offline
well it dumps the oil into the airbox, then it gets sucked into your filter, if any makes its way past it then goes into the turbo...
  #13 (permalink)
Old 17 Dec 2003, 07:43 pm
OurPTGT OurPTGT is offline
Not sure about that since they use that POS little sponge for a filter on the side of the OEM airbox. It just runs down the side and sits in the bottom. The bottom of the airbox has a small hole in it. If it gets to much seems it would run outa the hole[:I] Beats me though...[^]
  #14 (permalink)
Old 17 Dec 2003, 08:57 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
Words are hard to express online. You speak in ways that allow people to think that you are an expert and that it will be okay to try out some of your mods.
If you are a novice, as you say, then any advice you give should have teh added condition that it simply opinion.
Saying a "turbo mechanic" (whatever they are) told you to not allow the excess gas from the crankcase to vent and that (im waaay lost on the original post) you should connect it to vaccumn lines is decieving.
I keep thinking back to the cure for the POT code....removing the TIP sensor. Even a few threads later you warned that your IC piping needed to be reinforced (after running high boost), yet no additional comments were posted by other members, who may have followd your original advice.
I am a novice. And I believe I act as such. If there is doubt in my mind about the truth of my statement, I will add that additional info.
Im done ranting...
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
  #15 (permalink)
Old 19 Dec 2003, 03:46 pm
amx1397 amx1397 is offline
I am no expert, just a Pt Turbo owner that wants to learn, and help others Pt owners, so amoung us all, the Rice Bunners will say Damn I didn't know that Pt Cruiser was that fast. what I was saying is that a catch can (dead end) is no good, sorry for that misunderstanding
We all need a some type of catch can, oil getting to the turbo is a no no. The catch can could be a in line filter to stop the oil,(change or clean it often.) The system that Mean Green has is the best I have seen, the vent on the valve cover to a catch can, Then a line from the can to the manifold, Oil stays in can and the vac. keeps neg. pressure on the crank case. with more boost (stage 1 and or 2) check the oil your often.
As far as the boost hose from the turbo to the intercooler, yes it touches the body of the car and should be protected.(cover it with a bigger hose). punctuation! it is hard enough to type with two fingers, give a little and U want more. 18 lbs of boost yes,I do.
jim
  #16 (permalink)
Old 19 Dec 2003, 07:20 pm
026TB4U 026TB4U is offline
Send a message via AIM to 026TB4U
amx i too am a new owner the first car newer than 1981 let alone 1st turbo. have you run on a dyno or had an accurate air fuel are you sure you arent running lean?
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah
  #17 (permalink)
Old 22 Dec 2003, 09:46 am
Guages r being installed after first of year, exhaust temp, will be installed, with max 1400 degrees. As the air fuel, it is not fast enough, by the time it tells you what is going on it may be too late.After the pcm install I feel I am running lean. Have not reinstalled boost controller yet, only 100 miles on new computer.
jim
  #18 (permalink)
Old 25 Feb 2004, 04:52 pm
So I'm going to install a oil catch can after seeing some in person. I guess I didn't look close enough.
Here is my (first) dumb question of the day - is the airflow from the crankcase cover (PCV valve) toward the manifold? The catch can has an arrow on it to indicate flow direction, I just want to make sure I install it in the right direction.
I think the air is going from the PCV valve to the manifold but just need to be sure.
PianT
  #19 (permalink)
Old 26 Feb 2004, 12:41 am
flashbk2 flashbk2 is offline
That's how mine is installed .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
  #20 (permalink)
Old 26 Feb 2004, 12:31 pm
Thanks, did you leave the filter in the catch can?
I'm thinking it is not needed as we will just be throwing that oil out, is there an issue with blocking the airflow if it goes through a filter?
PianT
vB code is On
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
Catch can in quicksilverdon General Turbo Discussions 2 02 May 2005 10:34 pm
Oil Catch Can crazie.eddie General PT Cruiser Discussions 30 30 Oct 2004 06:23 am
What to do with oil collected in Oil Catch can? crazie.eddie General PT Cruiser Discussions 1 25 Oct 2004 09:20 am
Greddy Catch Can crazie.eddie Tech & Performance Forum 10 20 Oct 2004 03:00 am
  Xbox Mod Chips | Mobile Phones | Loans | Nepal trekking | Advertising
