This is interesting, I have the K&N Typhoon on my PT now. The bennies are that it spools faster than with the stock airbox, and the normal operating temp has dropped from 180 to 175. I just received the AirRaid today. I will put that in sometime next week to see what if any benifits it has over the K&N. Then I will try the FIPK to see what it is like, I will then keep the best of the trio and sell the other two. FWIWM2C macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
[quote]Originally posted by Ian-PT-GT
I think 3Bar Talked about the restriction the intake has on the turbo... Metal and plastic... metal absorbs heat faster than plastic. If you think I am wrong, Tower Hobbies sells an IR temp scaner that measures heat by just pointing to the item to be tested for about $30.00. After driving around, remove the filter and point the scanner to the inside of the filter housing. then do the same to the metal intake tube.. you decide. IF metal and plastic are the same conducting heat, how come there are no plastic cooling fins in amplifiers... If you don't want to buy a scanner, touch a plastic part inside the engine compartment and then touch a metal one... One will feel hot, the other one will burn you... Some people here have actualy covered their metal intake pipes with insulation. of course the outside will feel hotter, but air passing through the pipe doesn't have enough time to heat up, i will search for a link to a study done on this... punch |
I too removed the baffles on the air box. In fact I removed the intake plastic housing that runs to the fender well. That leaves about a 4" intake hole into the airbox which I insulated completely with a 1/8" rubber stripping. With the K&N drop in air filter, my airflow should be fairly close the the typhoons and others at a fraction of the cost.
Please see Forum Guidelines regarding signature image sizing. |
macster
k&n fipk at mopac in canada is 271.00canadian $$$ including tax
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah |
Don't get me wrong.
I was sold with the Airaid System but without the turbo-up pipe... I was still on the fence. I would buy the airaid in a sec if it also replaced the third and last silencer. For now, I am still interested in the FIPK. Ian
That looks just like my K&N "Aircharger" system. I guess they call it that until they get a CARB certification. Then they call it a FIPK?
Turbo inlet is fixed size. You could attach a barn door to the inlet, but it's still diameter.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
But, it's relative. E.g. You could have x amount of air going down a 3" pipe to a 2.75" opening or you could have 2X amount of air going down the same opening. Isn't the idea is to get as much air as possible down to the turbo? macster
| AirAid Turbo intake for sale /SOLD | 2step | Classifieds: For Sale/Trade | 4 | 18 Jan 2005 11:58 am |
| Typhoon intake | GTSteve | Turbo Performance | 1 | 19 Oct 2003 05:04 am |
| Airaid Intake | Meeks | Classifieds: For Sale/Trade | 1 | 27 Jul 2003 01:02 am |
| K&N Typhoon Intake system for PT Cruiser turbo GT | KN Filters | Turbo Performance | 1 | 06 Jun 2003 12:37 pm |
| my new airaid intake is in with pics. | cmypt | Tech & Performance Forum | 9 | 31 Jan 2003 11:49 pm |
