dyno done a few questioons
Old 19 Dec 2003, 07:03 pm
Send a message via AIM to 026TB4U
Default dyno done a few questioons
i did a dyno run today on a mustang dyno
1st run at stock with k and n filter
165.1hp @5250
171.6ft.lbs @3750
2nd run at 15psi
166.1@5250hp
207ft.lbs @3500
3rd run @17psi
182hp@54 mph
791ft.lbs@38mph
third run chart looks like detonation or lack of spark so as someone stated 15 psi is max on stock injectors
gains show 25hp at lower revs and 1 at peakbut almost 40ft.lbs at lower revs (1700-5000rpm)[?]
Old 19 Dec 2003, 07:08 pm
question what are the differences between a dynajet and a mustang dynowhich is better more accurate
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah
Old 19 Dec 2003, 07:09 pm
i was also told to hold off on k&n fipk til injen makes one for appearance and performance
Old 19 Dec 2003, 07:59 pm
wow thats alot of loss from the 220hp at the crank...
Old 19 Dec 2003, 08:40 pm
If you have an autostick, you can expect worse output. Also, depends on gear you run in. Lower gears yield less output, sometimes a lot less.
Finally, Dynojets are a bit optimistic. Like 10-15%. That's how the SRTs are able to make their crank rating at the wheels. Our chassis dynos (which are a brake as opposed to inertia dyno) yield about 200 hp for an 04 GT 5-spd.
PT GT - Fastest damn lease car I could hope to have...
Old 19 Dec 2003, 08:42 pm
Ya especially considering most make over 200 at the wheels stock!
AC
If it doesn\'t fit get a hammer. If it still doesn\'t fit, get a bigger hammer. - Jesse James
Old 19 Dec 2003, 08:53 pm
i have a five speed but i guess even if this dyno is out i still gained 35ft.lbs with my mbc
Old 19 Dec 2003, 08:55 pm
2nd gear also melted his rubber hose when he held back pressure
Old 19 Dec 2003, 08:59 pm
Check out this article on Dynoes...
http://www.turbomagazine.com/tech/0306tur_dynodash/
Ian
Old 19 Dec 2003, 09:12 pm
this dyno he siad was 100,000$ as compared to dynojet$40000
Evolution Performance Dyno Day - Saturday, 10/1 Evolution Northeast PT Forum 0 27 Sep 2005 01:12 am
Where to get a dyno test? kiteman3221 General Turbo Discussions 5 10 Aug 2005 12:26 am
Dyno Results for Hahn Turbo PT!! Ant Turbo Performance 7 09 Feb 2004 08:27 am
dyno danger 026TB4U General Turbo Discussions 0 11 Jan 2004 08:14 pm
dyno results kruzzinpt Turbo Performance 2 28 Jun 2003 09:52 am
