Reset Check Engine Light
Old 03 Jun 2011, 08:13 am
Exclamation Reset Check Engine Light
Hi Folks, just joined forum looks excellent. I am in the Middile East and my Wifes 2005 GT just went out of warranty, and the Check Engine light came on. She thinks it is the coolant level, once fill, and if that is the problem, will the light go out on its own?
Old 03 Jun 2011, 08:53 am
Question Re: Reset Check Engine Light
Hello again,
she did the error code check, and came up with " P 0481" below that was "donE", 2005 PT GT HO auto.. Can't seem to find this code, any help would be great.....todays temp 127F with a HOT breeze
Old 03 Jun 2011, 09:03 am
Exclamation Re: Reset Check Engine Light
Found the code, Fan Relay 2,. Once repaired, will it go off by itself?
Old 03 Jun 2011, 11:59 am
cruserdad1976's Avatar
Default Re: Reset Check Engine Light
no i dont think so but you can take the battery cable off for 5-10 minutes and the comp. will reset itself
Old 03 Jun 2011, 12:39 pm
RaineMan's Avatar
Removing the battery cable for 5-10 minutes will clear the code and the light will go off. Whomever you are having replace the fan relay should unhook the battery anyways as it is a bad idea to work on anything electrical with the battery connected.
Old 05 Jun 2011, 12:37 am
Talking Re: Reset Check Engine Light
Thanx, everyone!. And as I said before excellent group. I will be doing the work. Thanx again..
Check Engine Light vgf11 Tech & Performance Forum 9 20 Jul 2017 02:01 pm
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Alternative way to reset the check engine light? drbranko Tech & Performance Forum 3 11 Apr 2009 12:43 pm
Engine Check Light IRPT Tech & Performance Forum 11 27 Jun 2004 10:24 pm
