PT Cruiser Forum Car Videos
Custom Wheels
Turbo Assembly going Kapuut?
Old 28 Dec 2003, 08:48 pm
ptgtcb ptgtcb is offline
Default Turbo Assembly going Kapuut?
Since I bought my PT GT the car has made a whirring/buzz noise most noticable in the morning/cold. This morning I started my PT and a puff of blue smoke came out the tail pipe, not good.I have not driven the car very much in the last few weeks and pulled it in and out of the garage last night but this really should not allow oil into the intake. Either the valve stem seals, rings, or the turbo are letting oil past. Just to check I pulled the inlet from the air box to the turbo off to check for oil at the inlet, none found.
However, I reached in and checked the turbine for any play and found at least .030 play. I can wiggle the turbine up and down. Looking in with a light I can almost get the blade to touch the housing. From my experience this is a no-no for turbos, there should be no play in the turbine blade assembly. The bearing/housing is going south.(3,700 mi.)It also appears that there is a little exhaust getting in to the inlet side, soot and it smells like exhaust. I am going to take it to the dealer but I expect them to give me a hard time about it since it has not failed. I do not want it to fail and send shrapnel/oil etc. into the intake! Good thing I have not installed my Stage I yet as this could have easily been blamed on stage I.
What do you cruisers think?
How should I approch the dealer?
Old 28 Dec 2003, 10:16 pm
COP TZER COP TZER is offline
There may be leaks in the oil cooling lines for the turbo. Be very careful about how you approach the dealer. Make sure your car has NOTHING on it in terms of mods. My assembly went at about 20K, and the dealer blamed my BOV. Learn from my experience...
My Cruiser is slow. I love the law.
Old 29 Dec 2003, 06:32 pm
BUBBA-KONA BUBBA-KONA is offline
I had a simular experiance... see my post on 9/12/03. Big cloud of smoke. Turbo had to be replaced. Bearing failure .. Good luck!
WHITE 03 TURBO, BTG intake, BTG axle back exhaust Build date:8/7/02
Old 29 Dec 2003, 06:56 pm
Yes, I remember your post and I re-read them. Do you remember if they told you the amount of axial play found or the spec? Sounds to me as if there should be very little axial play. Thanks!
Old 29 Dec 2003, 09:24 pm
bobs turbo pt bobs turbo pt is offline
have you had it to them for this problem already??
Old 29 Dec 2003, 10:41 pm
No, I want to find out as much as I can before I go complaining about it.
Thanks
Old 30 Dec 2003, 03:16 am
Punch Punch is offline
according to the service manual blue smoke could be:
oil return line blocked
engine breather clogged
turbo shaft seal damaged
Old 30 Dec 2003, 03:22 am
http://www.turbomagazine.com/tech/0304tur_broken/
Old 30 Dec 2003, 01:49 pm
Thanks Punch,
Good article, .003" to .006" for axial play sounds about right to me. Chryslers spec who knows? Does your manual list a spec for the axial play? I have to get a factory manual, I usually wait until the car is out of warranty.
Old 30 Dec 2003, 05:05 pm
if it does, i can't find it?????
vB code is On
Best Air Filter assembly for Turbo? nozzano22 Turbo Performance 6 30 Jun 2004 04:58 pm
Turbo leaking oil 03baggedturbo Turbo Performance 5 09 Dec 2003 09:54 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
  Advertising | Mortgages | Houses for Sale | Loan | Loans
