boost and head gaskets
Old 30 Dec 2003, 01:36 pm
Default boost and head gaskets
Does anybody know how much boost the "stock" gaskets can handle?
Old 30 Dec 2003, 01:54 pm
The "stock" head gasket is also the best on the market. ow much boost is relative to fuel air mixtures and combustion temperatures. Run lean, run hot, run out of luck!
Old 30 Dec 2003, 02:05 pm
I sure wouldnt run more than 16 psi but not sure of the exact numbers
Old 30 Dec 2003, 02:14 pm
just to let you know, I run 18 on the street
jim
Old 30 Dec 2003, 02:17 pm
Good to know! thanks!
I'll be using water/alcohol injection, an intercooler sprayer, and aiming to keep A/F to 12.5.
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
Old 30 Dec 2003, 02:41 pm
16 psi - based on the gasket, or other constraints? I have detonation and combustion temp issues covered for the most part, but I was curious about the limits of the gaskets. If the A/F ratios let me run up it to 20psi in the second stage of the MBC, then I'll be running 20 psi
Stock PCM's run rich at WOT for anti-knock purposes usually - it dumps fuel to keep the temp down. The water/alcohol injection does a much better job of that, so the boost at WOT can now be upped to take advantage of that extra fuel already programmed into the system.
disclaimer: I am not a professional mechanic, just an enthusiast.
- Stage 1
Old 30 Dec 2003, 02:52 pm
JasonL you might consider a pyrometer as well if you are going to tune. A/F is necessary, add a pyrometer and you will have information on all of the factors included in combustion. That is my 2 cents..........
Old 30 Dec 2003, 03:02 pm
gear head - good point on the pyrometer. I will look into it.
- Stage 1
Old 30 Dec 2003, 07:16 pm
Jason,
I can't speak for the PT ( I haven't play with mine yet) but I running 24 psi boost in my neon R/T without any problem and alot of tuning. I am running with Mopar Multi-layer steel headgasket, which I believe in what Mopar is using in all their 4 cylinder motor since late '98.
I hope this helps.
Tommy.
Old 30 Dec 2003, 08:31 pm
awesome, thanks for the info Tommy!
- Stage 1
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
Head to Head with WRX JohnM General Turbo Discussions 21 22 Nov 2004 04:45 pm
Head bolts for the Turbo? Airbillster General Turbo Discussions 11 16 Dec 2003 11:05 am
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
head gaskets Turbo Tommy Turbo Performance 5 17 Jul 2003 02:27 pm
