Loss of power and turbo
Old 28 Jul 2011, 11:53 pm
Default Loss of power and turbo
2005 Turbo 90000 Had code p0340 and p0344 I changed cam sensor. No more codes. It does not have power, especially uphill. Checked leaks it seems to have good exaust out tail pipe. I do not here turbo kick in. Will take it to shop in 2 weeks any ideas until then? Thank you in advanced.
Old 29 Jul 2011, 12:46 am
Default Re: Loss of power and turbo
Check for boost leaks. Put zip ties on all vacuum lines. Put t-bolt clamps on the intercooler hoses in place of the crappy worm drive clamps.
Old 29 Jul 2011, 02:53 am
golf55555's Avatar
With that much power loss, sounds like the turbo has locked up, or wastegate stuck open? I have a stocker turbo for sale if that's the problem. Hope you get her fixed!
SOLD-----K&N FIPK CAI, MSD wires, NGK plugs
03 Dream Cruiser series 2 #1489,5sp
k&N FIPK CAI, MSD 8MM wires, NGK iridium plugs, oil catch can, AGP wastegate, Mopar BOV,Mopar Boost Gauge,Stage 1 injectors,DSP Sport tuner,VSR Anima 18" wheels, Kelly 225-40-18 tires, 3" cat delete downpipe, APS SS dual exhaust.
Now owner of a black CSRT stage 1.
Old 29 Jul 2011, 07:39 pm
With those crappy worm drive clamps on the intercooler (IC) hoses I had a boost leak straight from the factory. A vacuum hose that popped off could cause that problem. When the IC hose popped off of the throttlebody my GT would run fine untill you tried to get on it with the turbo.
Old 31 Jul 2011, 09:08 am
If the turbo is not working should I have a code? Again I do not show any codes. Thank you.
Old 31 Jul 2011, 11:53 am
golf55555's Avatar
No, you will not get a code for the turbo locked up. But do the checks as others have suggested. Intercooler, vacuum lines, etc...
Old 09 Aug 2011, 12:40 pm
They said it was a bad turbo, Needed a second tech to diagnose it. They wan 2300 for a remanufactured on. Can't afford now, will I hurt the car if I drive it?
Old 09 Aug 2011, 12:49 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
i've got a used one with only 8k on it. near new. i'll let it go for 400.00. shipped.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 09 Aug 2011, 03:33 pm
Thank you I will talk to the mechanic
Old 22 Aug 2011, 08:00 pm
Chris_TurbosUnleashed's Avatar
Check the following link out for installation assistance and turbo replacement options:
http://www.ptcruiserlinks.com/forum/...albums229.html
Rebuilt PT Cruiser turbos start at $350. with a 1 year warranty. New PT Cruiser turbochargers are currently on sale for $400.-$500. with up to a 2 year warranty.
Thanks!
Chris-TU
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Tags
camshaft position sensor, turbo
Power loss in '06 GT Joven76 Turbo Performance 12 30 Aug 2011 05:42 pm
Power and MPG Loss Smurfy Tech & Performance Forum 10 28 Jun 2011 08:31 am
Loss of power slcpunk Tech & Performance Forum 9 15 Apr 2009 12:51 am
Power loss littleblueGT Turbo Performance 3 11 Apr 2006 11:45 pm
Power Loss LoboMXGT Turbo Performance 2 15 Aug 2005 04:00 pm
