Blow off valve.
Old 09 Aug 2011, 01:39 pm
Turboguy85's Avatar
Default Blow off valve.
Hey cruisers, I was wondering where one could find a hard up-pipe for my cruiser. If it has a Bov flange already welded on etc....Im not looking for the mopar plate. Thanks.
2003 Dream Cruiser #0794, MSD wires, MSD Box, Borla exhaust, K&N coldair intake, Rear fiberglass rollpan, Xenon side skirts, Rear window cover. Pinstriping on tailgate and hood.
Custom teardrop tailights, drilled/slotted rotors. Custom interior, boost gauge and wideband in A-pillar, lowered on Ebach adjustable coilovers, sway bars, and bushings. Diablosport Intune with modified 93 tune. AGP aftermarket wastegate. Fresh rebuilt engine with forged wiesco pistons bored. 020"over.
Old 11 Aug 2011, 02:32 am
Kawizx9r's Avatar
Default Re: Blow off valve.
Performance auto parts & aftermarket auto accessories for your car, specializing SRT4, Crossfire SRT6, SLK32, C32 AMG, VR-4 will have one, made to order but they're a bit pricey.
DEJON | Powerhouse is where I got mine, and you can buy it with a flange already welded on. I got mine welded on later down the road because I wanted to use the pipe already and didn't have the funds for a BOV yet. When the time came, I bought an HKS SSQV BOV and welded the flange onto the pipe and installed it.
Btw, make sure that whatever pipe you get..if you plan on welding the flange yourself get the same-type metal flange as your pipe. The aftermarket pipes are mild-steel whereas some BOV manufacturer's provide an aluminum flange, that's a no-no you'll want a steel flange to weld onto the steel pipe.
Kawi is a friggin genius!
Old 11 Aug 2011, 06:33 pm
Are you going to be running high boost cause otherwise you don't need it unless you are putting it on for show. Does look and sound cool, though. Won't be any performance benefit with just stock boost.
Old 12 Aug 2011, 12:26 am
Turboguy85's Avatar
thanks I really appreciate it. My cruiser is now stage1, and I also figured it would stop the fluttering of my turbo when letting of the gas. Also I know how to weld and was planing on doing it myself. I have seen people try to weld aluminum with steel and I just shake my head and say, cant say I didn't warn you.I actually make gas tankers for semi's to haul fuel. Im the lucky guy who has to crawl inside em and weld the baffles. But it does get me away from everyone...
Old 13 Aug 2011, 02:02 am
If you can make your own then go for it.
Old 03 Feb 2012, 01:14 am
I know this is an old thread, but through DEJON | Powerhouse Would I have to buy both the UPIC-PTA & the UPIC-PTB or could I just buy the UPIC-PTA (with flange) and run it down to a stock tube?
I'm obviously new at this so I have no idea, thanks ahead of time Kawiz!
Wife's White 2002 Limited: Konig 17" Rims, 5000k White HID Head Lights,
My Red 2003 GT: Sold.....
Old 03 Feb 2012, 12:49 pm
03GTCruiser's Avatar
Only getting half would defeat the purpose, as the stock portion would still balloon out before letting the boost pass on. If you want just a BOV, you can always get a small piece of pipe and weld the flange on it and put it where ever you can fit it in your stock pipe.
Just remember before cutting up your stock piece that it's kind of pricy to replace (think it's in the $150's)
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
blow off valve SuperGirl Tech & Performance Forum 24 25 Apr 2013 07:57 pm
Blow off valve problems pls help! stjimmy2009 Turbo Performance 1 17 Sep 2009 11:45 pm
what is a blow off valve careyk General PT Cruiser Discussions 3 17 Apr 2008 01:23 pm
Mopar Blow-off valve kit. beachknight Turbo Performance 16 04 Mar 2006 11:16 pm
Stock blow off valve DMW General Turbo Discussions 8 12 May 2005 06:08 pm
