If you are still using the stock champion plugs check them often.Even if you close down the gap for better performance they are still too hot for turbo application.The champion 3032 single platinum plugs are one heat range cooler, but I noticed they have a problem with the internal pressure seal exhibited by verticle brown traces from the metal crimp up the insulator.The NGK 4306 plugs are a heat range cooler than stock and showed no signs of leakage and have not shown any signs of insulator cracking around the electrode as the stock champions have.What's worse is when the insulator ceramic chips off inside the engine causing damage.I hear NGK is coming out with a heat range "6", but I can't confirm that yet.
i want a hotter ignition box. what are you guys using/recommened.
im using stock plugs with mopar wires running bout 13 psi on an Apexi B-controller.thx
03 GT |
So what happens if you run a plug too hot? Do you just burn or melt it out? Do you also run the risk of burning or melting out the wires, too?
![]() <b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i> |
littleblueGT Posted - 10/05/2004 : 12:38:25 PM
-------------------------------------------------------------------------------- Quote:
FYI, NGK copper plugs, LZTR5A-13, stock # 4306, 1 heat range cooler than stock plugs. NGK Iridium plugs,LZTR6AIX-13,stock# 2315, 1 heat range cooler than NGK copper plugs LZTR5A-13
03 Silver GT Turbo 5-Speed |
I heard that the the 2005 SRT-4's now use a gapping of 0.045 instead of 0.050.
| E3 Spark Plugs | CREWZIN | Tech & Performance Forum | 6 | 11 Dec 2004 01:03 pm |
| Spark plugs: newbie question | Edwin Astacio | Tech & Performance Forum | 12 | 01 Nov 2004 12:21 pm |
| ZEX Spark Plugs | Jerry | Tech & Performance Forum | 9 | 27 May 2004 07:32 pm |
| Ignition Questions....need help. spark plugs | ptcruzin42 | Tech & Performance Forum | 5 | 15 Mar 2004 08:39 pm |
| Spark Plugs | kidturbofan | Turbo Performance | 2 | 08 Oct 2003 10:40 pm |
