Replacing Spark Plug Wires
Old 07 Jan 2004, 11:36 pm
Default Replacing Spark Plug Wires
How difficult is it to replace Spark Plug Wires, is there anything tricky or that I should know. Is there a thread on this procedure?
Old 07 Jan 2004, 11:58 pm
Here's a guide on replacing the spark plugs, it covers removing the spark plug wires.
http://www.ptdoityourself.net/ptplug.html
2002 Inferno Red PT Limited
Mercedes Wiki
Old 08 Jan 2004, 05:32 am
Thanks for the info. It looks like there will be little difference on GT!
<b><font color=\"red\">2003 LT ALMOND GT</b></font id=\"red\">
<font color=\"blue\">MODS:</font id=\"blue\">
Stage I, Custom Pin Stripe, Rear Spoiler, BTG Polished Strut Tower Brace, Borla 2.5\" CAT Back Dual Exhaust, and AirAid Intake System, Polished Front & Rear Sill Plates, Chrome Antenna Bezel w/10\" Chrome Billet Antenna, Mobil 1 and K&N Gold Filter, \"Flame\" 3rd Brake Light, \"Streamline Design\" PT Cruiser Visor, Rear Shelf Graphics and Dash Dots on Steering Wheel, and MGW \"GT\" Auto Shift Knob,Chrome Door Lock Pulls, Chrome Billet A/C Knobs with Acrylic Red Inserts, Chrome Oil Cap, Chrome Dip Stick, Chrome Radio Knob, Blane\'s Hood Lift Kit. Chrome Raidiator Coolant Bottle Cover, Timing Belt Housing Cover, Shock Tower Covers w/Nuts, Power Brake CYL Cap Cover, Windshield Washer Cap Cover, A/C Line Connector Cap Covers, A/C Check Valve Cap Covers and Radiator Cap Cover. \"GT2\" Rolo Red Calipers, Magnecor 8.5mm Spark Plug Wires - Red, Red Wire Looms, Billet Aluminum Steering Wheel Caps (4), Chrome Coin Tray Trim Cover, Chrome Shifter Bezel Tirm Ring, Yoko AVID V4S - 215/50/70\'s, TYC Euro Style Back-up Lights, and Screamin Demon Coil
Old 08 Jan 2004, 08:46 am
Lt Almond GT, sorry. Here you go, this is from the 2003 service manual:
REMOVAL - 2.4L TURBO
Special care should be used when installing spark
plugs in the 2.4L cylinder head spark plug wells. Be
sure the plugs do not drop into the wells, damage to
the electrodes can occur.
NOTE: REMOVE cables from the coil first before
removing spark plug insulator.
(1) Disconnect the negative battery cable.
(2) Unlock and disconnect the MAP sensor electrical
connector.
(3) Remove the throttle control shield.
(4) Disconnect the cable from the ignition coil first.
Always remove the spark plug insulator, rotate the
boot 90° and pulling straight up in a steady motion.
(5) Remove the spark plug using a quality socket
with a rubber or foam insert (Fig. 30).
(6) Inspect the spark plug condition.
Mercedes Wiki
Old 08 Jan 2004, 10:49 am
Send a message via AIM to macster
connector.
I would add one thing based on personal experience. I would also remove the Map Sensor. I would definitely rotate the plug wires before I start to pull them up. They are locked on the plugs (almost like vacuum sealed tight) and its a bit disconcerting at first when you try to remove them.
FWIWM2C
Macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Spark Plug Wires thegoldpt Tech & Performance Forum 22 24 Dec 2007 11:08 am
How to do spark plug wires? thegoldpt Tech & Performance Forum 20 17 Jun 2007 01:27 pm
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
