motor mounts
Old 26 Aug 2011, 03:06 pm
Default motor mounts
i know i have read thinks here about gt's eating up mounts,but i break the studs..hmm
Anyone know of good aftermarket mounts not just the inserts??
Thanks.Rob
Old 26 Aug 2011, 03:12 pm
Default Re: motor mounts
The inserts are the best if you are automatic.
Old 26 Aug 2011, 08:00 pm
Its not my poly inserts, i'm snapping the stud thru them in my upper right and lower but my trans is fine.As of now i only see one way out, the one i dont wish to have ...Solid mounts. any thoughts you guys?
Rob
Old 26 Aug 2011, 09:10 pm
xwing777's Avatar
Yeah lots of places (srt4 neons use the same) heres a couple of trusted sellers:
MPx High Strength Motor Mount Bolt Kit 00-05 Neon
Boomba Racing Engine Mounts Bolts Set Dodge Neon SRT-4 - Modern Automotive Performance
Old 26 Aug 2011, 09:22 pm
That's what I have but I'm 5sp. I was told it shakes too much for an automatic, and turns unbearable when you use the AC.
Old 26 Aug 2011, 10:05 pm
xwing777's Avatar
I have the poly inserts, auto tranny and its about all you would want in an auto. I have a vibration thats slightly noticable stopped in drive with AC off. Stopped in drive, AC on....you definitely feel it but not bad.
Some with solid mounts and auto say the wipers bounce off the windshield if stopped in drive and AC on.
I did bump my idle up slightly using my diablo programmer to lessen the vibes. You can also make some very firm mounts by filling the factory with urethane.
Old 26 Aug 2011, 10:12 pm
nevinsrt's Avatar
i had poly inserts on my old auto. worked great and no issues. on the Neon i had inserts them went to solids and went back the stock mounts and filled the inserts since the solids were vibrating the insides since i gutted the car. sold them to some kid who now has a vibrating dash and other parts lol. there is nothing wrong with inserts or filled mounts. they work just fine.
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 29 Aug 2011, 04:22 pm
Thanks for your responce just ordered them...
Thanks Rob
Old 29 Aug 2011, 08:28 pm
mattsptgt's Avatar
My top right just went out is it easy to change ur self
Old 29 Aug 2011, 08:34 pm
Yes uppers are fairly easy...............Rob
Motor Mounts go-vair Turbo Performance 14 03 Apr 2017 10:50 pm
Motor mounts going bad wasmussen General PT Cruiser Discussions 31 07 May 2015 07:23 pm
Better Motor Mounts scatgo Tech & Performance Forum 2 28 Dec 2011 02:48 pm
Motor mounts sdwilson Tech & Performance Forum 8 03 Aug 2010 12:49 pm
motor mounts knowyourturbo Classifieds: For Sale/Trade 1 23 Mar 2006 07:36 pm
